Rear Axle Steering failure (991.1 GT3)
Larry Cable (02-10-2022)
I had the RWS go off at the track and it did not go back to a regular car, it severly effected the stability management. A tech at the track was able to use the PWIS to restart the RWS and all was fine.
This should be covered by warranty as it's a mechanical fault (not a consumable part) but PorscheAG being difficult despite the car having full service history at main dealers.
But there are enough links on the rear suspension that it shouldn't just start flopping around. For sure must be a scary feeling on track or at high speeds.
Glad it all worked out!
Another reason I hate RWS. I wish we could somehow cancel it out with a PIWIS, if so, I'd remove them and put in good old fashioned fixed toe links.
First I've heard of the actuator link actually breaking, but I agree that if broken the wheel will go out of alignment since it would normally be one of the multi-links. Also agree that it should be a warrantee issue.
I did have the rear wheel steering fault warning, along with a whole bunch of other wheel/brake/traction warnings, come on once. I trailered the car to a track on a 9 hour drive over bad roads. At that time I was still putting straps on the wheels to secure the car. When I got back home, all these warning messages came on as soon as I started the car. Drove the car down the ramp and around the block, it reset itself. Now I secure the straps to the jack points, never had the problem again.
I have them on my car.
