ST rotors, Forgeline GS1-R 19 wheels, GMG gen 2 half cage, DSC controller for sale
My 991.2 GT3 RS has been traded in so I am offering the following items for sale:
Surface Transforms CCM rotors $5,000: These have 12 days, approximately 1,000 track miles, on the 1st refurbishment. Probably have 20 more days (or more) before they need to be refurbished. Can be refurbished up to 5 times, so these rotors have another 100-120 track days still left with refurbishment. Refurbish cost: $800/rotor. These run 12-13K new. These work with the red or yellow calipers. Also have Pagid RSL-1 pads that have 8 mm left. These pads will be included in the sale. They have an aggressive initial bite. Pagid RSL 29s also work well with these rotors.
3 sets of Forgeline GS1-R 19 inch wheels: Two sets are 2 years old. Both are shod with R7 Hoosiers, one set with 6 heat cycles, one set with 1 heat cycle. The 3rd set has only been used two days and are shod with a brand new set of Hoosiers, A7 on the front and R7 on the rears. Offering the two older sets for $2000/set and the relatively new set with new Hoosiers for $5,000. The GS1-R run $1,500 a wheel, so $6,000/set new. The Hoosiers run $1,800/set new. These are aggressively priced to sell!!
DSC Controller: Like new condition. $800 ($1,390 new)
GMG Gen 2 half cage in white: $500 ($2,845 new)
PM'd you.
Cheers
Cheers
What's next?
mipcar (12-17-2021)
SterlingatBOM (12-26-2021)
3rd Gear
what are the wheel and tire sizes?
I assume the 19" wheels fit over 991.2 standard Red brake calipers?
all the wheels are true, and damage free?
the GMG roll-bar bolts onto existing bolts? (no drilling)?
just some carpet cutting?
does the DSC controller work also with standard 991.2 GT3 (non-RS) PDK ?
I have a buyer for the two older set of wheels, the cage and the DSC controller. The single newer set of wheels and new Hoosiers are still available. Wheels are RS offset, will fit over Red or Yellow calipers, although the yellow calipers are tight. There is scoring between the caliper and inside of the barrel from rocks. The wheels are all true and knurled (important for running Hoosiers). The newer set has only been used 2 or 3 days so have very slight scoring on the inside of the barrel (see pic above). Wheel sizes: 19 x 10 front, 19 x 12 rear. The Hoosiers on the newer set are new, still with stickers. A7 for the fronts and R7 for the rears. Tire sizes are: 295/30ZR19 fronts and 345/30ZR19 rears.
SanDiegoDavid
you got pm, interested in the new GS1-R 19 inch wheels with Hoosiers tires.
