PCCB Retrofit procedure
Ex owner upgrade it to PCCB’s as to my knowledge they only swapped the calipers and discs nothing more done. Is there any more parts to change or need to do coding on ABS etc.?
I had mine retrofitted a few months ago and I got new brake lines and caliper bolts. Both are longer than the ones that bolt to red caliper bolts. Also there's some coding for the ABS and e-brake.
