2016 991.1 GT3
Are the 2016 GT3’s affected by the known engine issues? From what I found online they receive the 10 year 120k mile warranty but I believe these have the “G” engine which is not affected? Can someone confirm?
Solid Enjoy it plus you got til 2025
All 991.1 GT3s potentially have the FF issue but as Porsche progressed 2014 thru 16 there were changes made to each new version that made the issue less likely. However you can have a 2016 with the original G engine that came in it that is not the replacement motor.
itrsteve (10-07-2021)
No, the only way I know of is the label on the top right of the deck lid. I have a G0 engine ('16 GT3) and no issues so far at 17,800 miles. There have been very few G0 failures due to the finger follower issue that have been talked about. The oiling system of the first gen G series is the same as the RS. The engine is identical except for the bore and stroke. Frankly, there have been quite a few failures in the RS but not systemic like E and F series engines in the '14 & 15 GT3's.
This is correct but it is vastly different than the E & F engines. The E engines were the original in the 14's and early 15's. The F came in the 15's and replaced the E failed engines. The G came in the MY16 and was different in how it oiled the engine, along with the new coating on the FF;s.
RDCR (10-08-2021)
RDCR (10-08-2021)
Doesn't make any abnormal noises, blow giant puffs of smoke every eight times you start it, etc. The old one certainly had some personality to it.
