Spark plugs
My dealer tells me that I need to replace the spark plugs on my 2019 GT3 RS every two years due to the incapatebility of the aluminum heads vs the steel spark plugs.
Replace the plugs, as per Porsche's recommendations, every 2 years. It's an easy DIY.
With the DFI engines it's easy for the plugs to get carbon welded in, if left too long. Plus these engines are hard on the plugs.
I agree - replace them. And if you aren't handy (I'm not), it's not a pricey thing to have your indy do. I think mine charged $600 much of which was the plugs themselves.
$147 and about an hour (if you include removing and replacing rear wheels which helps on jack stands) to put these in:
Spark Plug Set : Suncoast Porsche Parts & Accessories (suncoastparts.com)
Apex Ace (08-19-2021)
It's legit. While 2 years seems like a very short interval and the plugs themselves may be in good condition, the 2 year replacement interval is recommended due to the dissimilar metals.
How about just removing them and reinstalling them with a bit of grease on them? In 2 years, I only put about 5,000 miles on my car.
$147 every 2 years is not that big a deal (that's like a tank of fuel)...
Good point. I just hate throwing something away prematurely. Is the mettle of the plugs somehow changed after being in the heads after 2 years? What would be wrong with just removing and reinstalling?
I never considered reusing the plugs, but I suppose you could do it. Probably best to rotate the plugs into different cylinders and mind the special torque spec for reinserting plugs (different from new ones)
On a lawnmower or jetski, I wouldn't worry. On a $200K GT3, may the force be with you...
krell (08-20-2021)
I am with Rocky.. The plugs metal have already been thru hundreds of heat cycles along with being dissimilar metals.. The labor to change them is more valuable than the plugs. Peace of mind. If you already went thru the trouble to get the plug out, put a new one in its place and be done for another 2 years or so. I have seen plugs seize and take out aluminum threads with them. If that were to happen, it becomes a bad day fast.
Please take the advice of people who are pointing you in the right direction.
Good luck
Rich
Good luck
Rich
