991 GT3, GT3RS, GT2RS and 911R 2012-2019
OBD Tool to reset service reminder
Old 03-10-2021, 12:23 PM
911dev
911dev's Avatar
Default OBD Tool to reset service reminder
Would someone recommend an OBD tool to reset the annual service indicator/reminder message? I performed the required maintenance items and then some and now wish to remove the pop up message. TIY...
Old 03-10-2021, 12:32 PM
shapiroeric
shapiroeric's Avatar
Durametric works.
The following 2 users liked this post by shapiroeric:
911dev (03-10-2021), Rick GT3 (03-10-2021)
Old 03-10-2021, 12:42 PM
911dev
911dev's Avatar
Originally Posted by shapiroeric
Durametric works.
Thank you ^
Old 03-10-2021, 12:44 PM
boisenelson
boisenelson's Avatar
Durametric (as noted above)
Foxwell NT530
iCarsoft v2.0 POR
Any of these should suffice
911dev (03-10-2021)
Old 03-10-2021, 01:26 PM
911dev
911dev's Avatar
Foxwell NT530
iCarsoft v2.0 POR
Thank you
Old 03-10-2021, 02:50 PM
cscrogham
cscrogham's Avatar
Durametric works.
Not on .2 GT3 that I am aware, unless they have FINALLY updated their software which would be welcome news.
Old 03-10-2021, 04:54 PM
Todd B
Todd B's Avatar
Correct, Durametric does not work with the .2's.
I use the icarsoft POR V2.0
Amazon Amazon
Recently updated the software and it can now read a bunch of parameters in the ECU, still no overruns, But hours, mileage, and a whole host of other values can now be pulled.
Used it this morning for my spring oil change.
GT3_Driver (03-11-2021)
Old 03-11-2021, 12:09 AM
Body In White
Body In White's Avatar
AFAIK, all of those tools reset to 2y/20K miles vs. 1y/10K like a dealer service. If that bothers you, you can get a PIWIS III clone for the 1y/10K resets, but it’s kinda like bringing a nuclear warhead to a knife fight.
pissedpuppy (03-12-2021)
Old 03-11-2021, 01:16 AM
Todd B
Todd B's Avatar
Nope, the iCarsoft unit lets you reset the different types of service reminders just like the PIWIS
Old 03-11-2021, 07:31 AM
911dev
911dev's Avatar
I'm likely going this route with the iCarsoft unit. The maintenance reminder is at the three year mark for an oil change for me. I changed the oil of course and did another brake fluid flush. The reminder was apparently reset by the dealer a courtesy at the two year anniversary as I had a warranty item completed. I completed the plug change, oil & filter as well as A/Fs, pre-filter and cabin as a DIY at that time. I did not realize until this year that the dealer changes about $100 to reset the reminder.
Thanks to all above for the info.
Old 03-11-2021, 09:33 AM
Captain_
Captain_'s Avatar
Hi Todd B. I have an iCarsoft V2.0POR, but mine looks a bit different than the one on Amazon and I haver never seen the function where you can reset the cars service interval like done with the PIWIS II/III.
Do you maybe know if this feature is an update?
Old 03-11-2021, 10:43 AM
Todd B
Todd B's Avatar
That's the icarsoft Por-II, it's different. It's an earlier model. I initially bought that version and discovered it did not work. I returned it and bought the newer version POR V2.0. The units do run different software updaters. So I suspect the hardware is different. I don't know if there's an update now for that version or not. My suspension is that Porsche updated the OBD protocol and maybe the chips in the earlier unit cannot support the newer protocol. With that said, I did see in another thread that somebody said they updated their POR V2.0 and it's working. So it's worth a shot for you to update and see if it will work.
Captain_ (03-11-2021)
Old 03-11-2021, 10:49 AM
Captain_
Captain_'s Avatar
Thanks so Much Todd!
I wrote iCarsoft and asked them.
Old 03-11-2021, 10:50 AM
GrantG
GrantG's Avatar
Received 4,780 Likes on 2,725 Posts
I love that you have the Konradsheim Carrera RS book! I have had one since new myself (they go for crazy money on eBay...)
Old 03-11-2021, 10:53 AM
Captain_
Captain_'s Avatar
Hi Grant. Yes, I was chocked seeing the prices of them. Guess it's because it's not so often Porsche them selves are authors of Porsche books? And the fact it's limited to a series of 3000 books.
Quick Reply: OBD Tool to reset service reminder
