991 GT3, GT3RS, GT2RS and 911R 2012-2019
Michelin PS4S in stock RS size
Old 02-03-2021, 04:12 PM
Wind911
Wind911's Avatar
Default Michelin PS4S in stock RS size
I ordered a set of Michelin Pilot Sport 4S in RS size (265/35/20, 325/30/21) and in N spec. I plan on use these on the street or when the track gets too wet. I use a set of Forgelines with Dunlops for dry track duties.
Tires arrived Monday, and the fronts are a smidge wider than stock Cup2, but the rear is more than 20mm narrower ! Tire Rack listed the 325/30-21 tread width 11.5" for the PS4S and 12.8" for the Cup2.
Front: Cup2 vs PS4S
Rear Cup2 vs PS4S
The following 4 users liked this post by Wind911:
catdog2 (02-12-2023), CX_GT3 (02-09-2022), pepinozaur (02-18-2023), whojoemama (02-09-2021)
Old 02-03-2021, 05:28 PM
GT3Lee3
4th Gear
GT3Lee3's Avatar
Hmm interesting. I'm literally going through this exact process right now thanks for posting. I'm wondering about upping the rear size? Only seeing a 355 is next up after 325 which seems a bit much. What did they look like mounted I wonder? How you liking them? Im in Houston also I am going to give the mobile tire guy a try and see how it goes everybody is saying they are great!
Old 02-03-2021, 06:14 PM
A418t81
A418t81's Avatar
Yep. This is a known “issue.” You have to step up to the 355s to get similar tread width.
The following 3 users liked this post by A418t81:
no401k (02-18-2023), usrodeo4 (02-04-2021), whojoemama (02-09-2021)
Old 02-03-2021, 06:22 PM
Wind911
Wind911's Avatar
They look pretty stretched mounted on stock wheel. I have not mount them on the car yet.
If you go 355/25 the overall diameter is 0.7” shorter. Which mean you’ll lower the rear ride height by about 9mm, also increase the fender gap by 9mm.
Old 02-03-2021, 09:40 PM
twk63
twk63's Avatar
Default Rear tires
I am going through the same problem, replacing my Cup 2 tires with the PS4S.
is the consensus to go with the 355 rear section PS4S tires? Any issues other than the reduced diameter?
Old 02-04-2021, 12:04 AM
Wind911
Wind911's Avatar
Another problem is the 355 at $907 from Tirerack costs almost double than the 325.
Old 02-04-2021, 04:16 PM
RLNTL3S
RLNTL3S's Avatar
Here's a photo of 4S on a my GT3 rear wheel for comparison.
Old 02-04-2021, 04:37 PM
usrodeo4
usrodeo4's Avatar
Yeah I would not run those, especially at racing speed...you are tempting physics fate.
Old 02-04-2021, 05:50 PM
GrantG
GrantG's Avatar
Received 4,978 Likes on 2,816 Posts
Yeah, Porsche does weird things with the size on the back of the GT3 also. The stock size is a 305/30/20, but no tire in that size (aside from the OEM Cup2 and Dunlop) are safe to put on a 12" rim. The OEM 305 is as wide as all other 325's, but the sidewall height is like a 305/30, so you can't just go with a 325 without changing gearing, ride height, etc.
I think Porsche does this to provide an "Exclusive" to the OEM tire manufacturers, but by fibbing on the size, they are creating an annoying and potentially dangerous issue. I didn't realize the RS had the same issue...
usrodeo4 (02-06-2021)
Old 02-04-2021, 11:15 PM
Wind911
Wind911's Avatar
Michelin lists the stock size PS4S as replacement tires on their web site.
Old 02-05-2021, 12:38 AM
Wind911
Wind911's Avatar
Compiled a list of 21" rear tires for the RS. The 325's have the correct side wall height but various tread width between models.
The 355 PS4S has shorter side wall and might be too wide for a 12.5" wide wheel.
Also note that the Dunlops is the only 325 tire listed for 12.5 rim width.
no401k (02-18-2023)
Old 02-06-2021, 07:01 AM
991C2S88
991C2S88's Avatar
Front: Cup2 vs PS4S
Rear Cup2 vs PS4S
How were you able to get the rear 4S in N spec for the RS? They’ve been on back order forever and still show back ordered on tire rack.
Old 02-06-2021, 10:54 AM
Wind911
Wind911's Avatar
My contact at Discount Tires said there were 3 in the entire country, Michelin wouldn't release them unless to a Porsche dealership. He had Discount Tire's head office involved to get two for me.
Sold me for cheaper than Tire Rack too !
Old 02-06-2021, 08:59 PM
bsquare
bsquare's Avatar
I started with PS4S 325s and they were much too narrow/stretched compared to the PSC2s. Went to 355s and life is good. Yes, they cost 2x for no good reason, but they also fit properly.
Old 02-06-2021, 10:28 PM
Wind911
Wind911's Avatar
Can you please provider some pictures of the 355 mounted on the car? Preferably from the side and from the rear. Thanks!
AnthonyGan (02-07-2021)
Quick Reply: Michelin PS4S in stock RS size
