Can you please provider some pictures of the 355 mounted on the car? Preferably from the side and from the rear. Thanks!
I don't have great photos handy, but hopefully these get the idea across. First is with 325s and you can see they angle back well under the fender. Second is with 355s.
355s look great, much better fit. Any TC issues with the diameter?
Im about to do 345/30/20 PS4S on a 20x13 HRE wheel which has about the same diameter as your 355/25. Just curious what I should expect...
Thanks, Looks like I have to bite the bullet and order the 355's
The 355-21 or 345-20 rear tires yield similar F/R difference as people run R7 in 295/345 combo on the 19". So TC or ABS should be ok if those who track the R7 haven't report any issue.
I ended up getting a set of Michelin 4S 355/25/21 for the street and mounted them on OEM spec 12.5” wide wheels. When I compared them side by side with 325 cups on the stock wheels, they were exactly the same width. Fitment seems spot on, so another confirmation for the sizing option for anyone going with a 4s.
Yes the 355 PS4S is exactly the same width as the stock 325 Cup 2 but with shorter side wall. I have had them on for a couple months and so far no issue with TC.
