991 GT3, GT3RS, GT2RS and 911R 2012-2019
991.2 GT3 front bumper grille
Old 01-18-2021, 01:07 AM
NCheok
NCheok's Avatar
Thumbs up
Originally Posted by SmokinGTS
Here is what I did, take the bumper off and flip the grills. This will work until you rock chip the new side. Sure beats buying new grills. Powdered coated grills do not hold up as well as what came on the car.
You Sir, Win the Internet with this thread.
Old 01-18-2021, 01:10 AM
NCheok
NCheok's Avatar
Question
Originally Posted by Matrog
Use Dr. ColorChip on the grille. It masks little paint chips, and no one will see it down low. Eaiser than removing the bumper and flipping the grille around.
Our grilles are not exactly black, it's this color in between silver and black, like dark grey? Do you have a color code or link on what you bought that makes the touch up look, well ... as close to OEM as possible?
Old 01-18-2021, 02:34 PM
Ascetic
Ascetic's Avatar
Thanks, Cobalt, and redmonkey. Appreciate the info!
Old 01-19-2021, 11:44 PM
Matt-R20
Matt-R20's Avatar
Flipping the grills is the right way to go. Bumper removal is pretty easy and there a many write ups to guide you through it. If the second side gets too beat up, you could still pull the grills and rattle can them. If you want to be more OCD, I’d try a wheel refinisher as the grey paint is the same tone used on the wheels and they could easily refinish them in or out of the car (my preference would be out). At that point, new grills might just be less headache. Good luck!
Old 07-07-2021, 07:37 AM
Overdraft
Overdraft's Avatar
Reviving this thread. Can anybody give me a tip in removal of the retention frame which holds the grill(s) in place?. It is not intuitive!
Old 07-07-2021, 11:42 PM
9972RS
9972RS's Avatar
can we replace with 718/992 type grills? they seem to be stiffer
AnthonyGan (07-08-2021)
Old 07-08-2021, 12:15 AM
Overdraft
Overdraft's Avatar
Finished tonight…wasn’t as bad as I thought…but a task nonetheless…
Old 07-08-2021, 01:20 AM
Ascetic
Ascetic's Avatar
Any tips? I'm doing mine in a couple weeks.
Old 07-08-2021, 08:14 AM
Overdraft
Overdraft's Avatar
Patience is all..and to be sure you have a very small torx socket to access 4 screws from the back which retains the plastic boomerang trim around the turn signals - which I had to go pick up at princess auto mid task. Put all your fasteners and clips in a sealed container like a yogurt tub when working on the car so you don’t lose track of them. Have someone handy to help you remove and replace the bumper cover - on a blanket - not to scratch. Don’t force (on or off) and bolts or electrical connections as they fit beautifully. I was relieved and happy that I didn’t have any extra screws at the completion of the job. Not rocket science….did I mention patience?
Old 07-08-2021, 07:28 PM
merc5326
merc5326's Avatar
They're Meteor Grey Metallic, an actual Porsche body color, offered on many Porsche models. Go to your local body shop and have them make you a bottle that'll have a brush built into the cap. Codes for different models are: LM7W, 9Q, 961 & LY7Z
Quick Reply: 991.2 GT3 front bumper grille
