Quick ? I have a 4 post with center solid inserts which frankly I can’t R&R anymore (don’t get old). Could this unit be placed on the lift deck itself (deck of 4 post about 4”) while on garage floor? Hydraulic lines routing ?
not really sure what it is you are asking here, so to err on the side of safety I would say "no", not sure why you would want to do this if you already have a system?
So you’re saying you don’t want to remove and replace your old lift but, while probably not recommended if your asking if you can drive the car on your current lift, leave it on the ground, then place these on the decks and lift the car the you’ll probably be ok. But probably is not really a great answer when your dealing with a car lifted off the ground
