Brake Fluids for GT3 Track Use...
#32
SRF is popular for its high boiling temperature typically for track use. Pricey and sometimes hard to find.
I use RBF660 which has a very similar boiling point. I boiled ATE 200 ONCE, so moved to one of the premium brands.
If you are not tracking the car, the top tier brands are overkill IMO
Fluid is changed because it is hygroscopic (absorbs water) with two years being the common industry standard.
More and more shops are testing the moisture content as the reason for changing, not just age. You can buy a DIY tester from Amazon for $11.99.
#33
9914s (09-23-2020)
#34
I have questions for you guys using Endless RF-650. I had my dealer flush my system and fill it today.
My dealer said because it’s silicone based I should flush after each track day. Are you doing this?
My brake system (maybe the booster) squeaks with this new fluid. I mostly hear it a low speeds. Does yours?
Thanks in advance
Thanks in advance
#35
Thanks in advance
Thanks in advance
Dreamer99 (09-15-2023)
#36
Thanks in advance
Thanks in advance
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/837x822/rf650_c9bea9a7b3798e780d1b5c876514b84d57ddbb21.png)
https://www.evasivemotorsports.com/s...e-fluid-500ml/
#37
I went out for good rip in the car today. Brakes feel fine with the Endless fluid, just a funny squeak you can hear at low speeds when you pump your brakes. Weird!
GrantG (09-15-2023)
#38
Castrol SRF from FCP Euro. Bleed before every track event, flush annually. I have been thru 4-5 quarts in the past couple of years with the lifetime replacement from FCP Euro. Its the best.
#39
Wait a minute, so you can first bought a couple quarts from FCP Euro and just keep sending the old fluid back and get new fluid for “lifetime replacement” ?
#41
Ran SRF in my GT4 but after a Manthey service where they swapped the fluid (they use Endless 650) the pedal feel is definitely firmer/better than before. I didn't think the type of fluid would matter much but only using Endless now in the GT3.
AdamSanta85 (09-17-2023)
#42
no squeaky brake booster with the Endless?
#43
