Over Rev Help
If there are 3 ignitions per rotation and 150 rotations per second (at 9k rpm), then there are over 450 ignitions per second in the over-rev condition. So, 62 ignitions means between 1 and 2 tenths of a second in over-rev.
And it’s possible that the car hit the limiter on multiple occasions and cumulatively has just over a tenth of a second in over-rev (the time of over-rev is given as the most recent, doesn’t imply there was just one).
great. Thanks for doing the math. Really minuscule.
I think the range 2 are false positives, mine also had 5 range 2 overrevs but then it said max engine speed was 9120 rpm so not sure how it can be a range 2 and sub 9200 thats why i initially asked OP if he knew what RPM they were at
What do you think about 30 overrevs in stage 3 on a manual car?
In 22000 km I never misshifted, the car feels and drives great... But during the warranty extension procedure we (me and my dealer) have found these 30 overevs in stage 3....extension done with no problem...
But I m still thinking about this strange discovery... .
Received 5,402 Likes
I assume you are the only driver and never recall this event so I logically am looking outside of your domain.
PS - Wishing you and Italian families good health in these serious times - Forza
Ps not from the dealer.... the car had 15 km when i picked up
Don't worry unless Range 4 or above.
Just to add a data point, running to the rev limit in a GT3 will show limited ignitions in range 1 (under 100) and a few false positives in range 2 (less than 10) and a high engine speed in the 91xx range.
cox1974 (06-29-2020)
Question- I get the Money shift potential but I thought you can not over rev while accelerating. Does it not cut off/stall if you go above 9000.??
I remember my 997.2 Turbo Manual would briefly hesitate if you redlined so you could not over rev while accelerating
If you were to run a report on your 997.2 TT, you might have seen a few Type 1 over-revs as well (even though you don't notice it on the tach).
