Do any 19" OZ wheels fit a 3RS?
Yep the OZ Superforgiata will fit. And just to be sure you should switch out the rear lower control arm bolt with a panhead bolt or grind the OEM bolt. It's a close fit and changing it out will avoid any scoring of the rim.
Not sure how much I'd trust Turtles if his cornering is consistently like his avatar... JK, kinda. But yes he is correct. That should work for you. Pain in the butt in my opinion, though.
What'd you go with?
What'd you go with?
Mr. Turtles (06-27-2020)
