PCA and sub-belt mount
Can you use a HANS with a 4 point? They say NO. Also, what prevents the waist belt from being pulled up onto the abdomen in the case of a sudden deceleration accident, resulting in abdominal injury? One of the shoulder belts slackens, effectively turning it into a street 3 pt. belt. That is what "ASM" technology means. Schroth recommends NOT using their 4 point belt in competition. The safety of a 4 pt. relies on being safely saved by an airbag.
Many years ago, I installed a 4 pt Schroth harness in an Audi. It made me think I was safer. It felt pretty "racey." One of our local events outlawed them. In my next car, I put in a roll bar, a 6 pt and started using a HANS.
The 4 pt. is clearly a compromise in safety compared to a 5 or 6 pt. It is much easier to install. Make any decision you want, but do it with both eyes open. At a minimum, if you are going to use a 4 pt then my recommendation would be to get a Simpson Hybrid Hans device. I say this as an 18 year DE instructor and as a physician.
4 points are the equivalent of Porsche buckets.
A compromise.
These posts are exactly why no one uses the 4 pts. I think they are a great compromise, an upgrade over the stock 3 points for sure, but people have so many different ideas of whether you can run 4 pts with Hans, w/o a roll bar, etc that you never know what you're going to get at tech. At that point it's just easier to get the 6 pts and not have to explain ASM and all that....
6 points, bar and a Hans device are a good choice if you want to avoid being on a first name basis with a neurosurgeon.
