PCCB on a mostly track car.
#31
gyroDisc steel rotors are a rotor/pad swap - no other equipment necessary - greatbrakes!
Perimeter (12-17-2019)
#33
Basic Sponsor
Thanks for the input, all.
The best deal I've come across on a used 991.2 GT3 comes with PCCB's, hence the question. The PCCB option vs iron brakes don't seem to factor in deals on used cars nowadays. I'm gonna buy the car. When you switch to iron brakes, you only have to change the rotors, right? Not the whole system, rotors plus calipers?
- Run them on the track until they are destroyed, and then replace with iron
- Set them aside and save them for when you sell the car
Front PCCB iron replacement (410mm)= https://www.essexparts.com/essex-des...1gt3PCCB-front
Rear PCCB iron replacement (390mm)= https://www.essexparts.com/essex-des...pccb-rear39032
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
#34
I understand quoting MSRP prices to help make your point but shop around and you'll find actual prices far less on RL - $12k for new OEM rotors and pads all around.
https://rennlist.com/forums/parts-ma...cs-pads-2.html
#35
Follow the money
That cross market sale brings OEM PCCBs into reality for US buyers.
I gotta ask, who is paying that $27k for OEM replacement brakes?
Nobody I assure you.
Once you get to half that number RacingBrake, Surface Transforms and others directly compete in that market and succeed.
#37
Seller has been supplying multiples for 7 months and continues..
#38
I asked the question to get feedback from 311RS of why in 4k track miles the calipers were having an issue. Assumed it was the simple rebuild from the heat but wanted to hear if there was anything else they actually found.
#39
Former Vendor
Run CCB fearlessly, use proper pads to preserve the life of CCB and if ever need to renew the disc consider this affordable option.
Refurbished discs are guaranteed to work better and last longer than OE or your money back, same warranty as our Caliper Rebuild Kits which hundreds of Porsche owners have experienced and witnessed.
Upgrade or downgrade? you decide by doing your own research.
In fact that's why RB brake offer is so popular among Tesla M3 owners.
https://www.racingbrake.com/category-s/7606.htm
#40
The ceramic pucks can be replaced with titanium from Autoquest, no? As per the ST vs these PCCB Brembos, the ST run much cooler... this i will be measuring at my next track day to validate the promises.
#41
How do the ST achieve cooler running temps? Are they just more efficient at transferring the heat to the air? Because the amount of heat produced is a function of the amount of slowing the brakes perform (should be the same for any adequate braking system and the best ones should produce the most heat).
#42
#43
Former Vendor
Iron and CCM are two totally different rotor material, other than lighter in weight, CCM rotor offers excellent dimensional stability, thus warp /crack that make an iron rotor un-serviceable is non-existence on CCM rotors, CCM rotor can also deliver highly consistent friction level and brake torque that an iron rotor can ever come close.
RB sintered brake pads are helping ZR1/Z28, Camaro ZL1, GT350, & Hellcat track racers running at their high confidence level w/o fearing of disc replacement. Our disc refurbishing program is your back up assurance in case refurbishing is necessary, all at minimal cost compare to CCB replacement from OE/dealers and downgrade to aftermarket iron brake.
Sorry for such a stupid long post. If you have insomnia, here is a cure…
Note 7 - I will apologize to RB in advance - to me, the discs end up looking butt ugly. That's just my opinion. I cannot argue against their performance regardless of the appearance. At one point we cleared the cross drilled holes, but there was zero change in performance. I never had an "out-gassing" issue like I have experienced in a Camaro with stock CCMs. To me they felt every bit as good as PCCBs, but still different and maybe with a slightly lower friction level (more pedal effort)...stress maybe and also stress this is not a bad thing, just different. If anyone is on the fence about this system and asks me, I can recommend the RB CCM set-up. The parts supplied were very nicely made and finished, and fit straight out of the box with no modification. Our set-up was an odd one for sure, but Warren was very reactive and quick to respond. I can comfortably recommend without hesitation.
#44
If you end up selling them after 2 years and 50 track days you are likely looking at fronts that can be refurbed another 2 or 3 times and rear rotors that can be refurbed another 4 times.
Everyone buying a used tracked car with PCCB treats it like it has ebola and assumes $25K in new rotors, but the ST rotors can be accurately depreciated through a quantifiable residual value.
PierreTT (12-18-2019)
#45
From the head instructor at the Barber Porsche Experience; he stated that the wear rate is about 3:1, PCCB to iron.
For them similar cost, they do save labor and down time, but their parts/labor cost is substantially less than ours. The PTX GTS models I drove with PCCBs had excellent brakes, but then again, we weren't pushing to the limits, close but not like an experienced driver would push.
