Hans device, 2 degree angled buckets, feedback.
Consider a Simpson device instead. Allows much more head movement and the hybrid model is also compatible with a classic 3 point belt. Tried an traditional Hans but went with the Simpson for comfort reasons.
Alan C. (11-21-2019)
Any time I'm in a street car on track I take my HANS off the helmet...does your car have 5 point harness?
JPSimpson (11-22-2019)
Simpson is the way to go these days
More comfortable and safer. Also its worth getting the FHR specific six points as well.
If you're running a 6 point then consider a Hans or Schroth. Both work fantastic but slightly different fitment and its personal which you will like better. Some guys like to get the seat angle adjustments, but myself I like it stock with no issues. I only see the Simpson when guys are running 3 point seat belts. Remember that most DE rules require both the driver and passenger seat belts to be equal so you will likely need the 6 point for both seats.
Aww, don't confuse me, lol... So Hans if using 6-point? I'm for sure running 6-point.
The references to Simpson above are for use with a 3 point belt. Running 6 point you are better off with either a Hans or Schroth SHR Flex or Hans III or Pro. Make sure you get the helmet brackets to attach it.
If you're not sure look for a shop in your area to go and talk with them and view the product, or if no one in your area call Clarke at Apexperformance.net. (I'm not affiliated just a customer)
Received 1,875 Likes
Can you please explain why a yoke style HANS would be better compared to a Simpson Hybrid using 6-point harness?
/JP
/JP
