Engine misfiring, bunch of codes, help?
I have a 2014 GT3 that had the engine replaced in 2018 under warranty at 38k miles. Just today I went to pick it up from being detailed and the car is in limp mode, throwing all sorts of codes, engine sounds rough as hell, and car can't be driven over ~17mph. When the car is started up the message says "Engine control fault" in yellow, then switches to a red "operating under reduced power - car can be driven" type message. It's being towed to the dealer for diagnostics, but maybe someone here is familiar with these codes and can offer some input. Doesn't look good at first glance but I"m not an expert. This is a G series engine: Anyone know what this might be? Going to need engine #3?
Link to codes showing - https://imgur.com/E066GDd
I’d check if the alternator is working or not - if it cannot supply enough electricity to the engine, the spark from the coils will be too weak and you will get misfire.
check the coils is also a good suggestion.
you also have camshaft sensor DTC, it could also affect the combustion on your engine and cause your engine to run roughly an ne the root cause of misfire if these camshaft DTC appeared before the misfire DTC.
Other usual suspects : sparkplug, intake leakage, make sure the oil cap is tight, is there any sensor disconnected, any purge pipe not connected etc.
A single coil failure will not cause a massive rough running engine. It would have to be more than one, which the statistical odds of multiple coils failing at the same time would seem to be low.
The codes seem to implicate cylinders 3 & 5, which I think are not on the same bank. So it could be something common to either the fuel or electrical spark or maybe a bad sensor (i.e., flywheel).
The shop should be able to nail it down pretty quick.
It does sound similar to this. Anyone know if the coils are covered as part of the engine warranty?
The engine was just replaced 3-4k miles ago so it would seem weird for spark plugs to not last that long. I see that the manual says 12k miles or every 12 months, seems like a really short interval time wise? Does everyone here replace them every year or just based on 12k intervals? Engine replacement was right about a year ago.
The coils are definitely under warranty. I had one replaced when it went bad right before the plugs started falling apart.
