In the corners, I'm sure it's (the GT3) not faster (than the GT4).
Originally Posted by GrantG
I think the strut rear suspension of the GT4 and the wheel/tire size stagger (front/rear) in the GT4 is revealed as a weakness on track fairly easily by a relatively quick driver (but maybe a more skilled driver than I can drive around it better).
I believe the GT3’s rear suspension is far more responsible for its ability to put power down (vs the GT4) than its weight distribution. Some recent Corvettes achieve tremendous rear traction with a sophisticated multi-link but far worse weight distribution than the GT4.
Agree with max. If there is any advantage, it's only realized with the real pro drivers. I didn't feel there was an advantage when I owned both at one time. The real advantage that the cayman has is the lower power. If you're trying to learn how to go faster, less power is always better and then transition to a faster car. I do it to a larger degree now between spec miata and the RS. Every Time I got faster in the GT4 I got faster in the GT3. Every time I get faster in my spec miata, it translates to a faster time in my RS.
Agree with you. I was underwhelmed by my GT4, didn’t keep it long. I guess we’ll see on the new GT4 but no interest from me.
Of course corner entry and mid corner speeds are comparable. And the GT4 exits corners as well as almost any non-GT3 car. It was funny watching that Camaro chase you at Sonoma; he seemed to get frustrated that you got a car length on each corner exit
The 4 is better on corner entry through mid corner where some of the recognized issues begin to show. The turn in transition favors the mid-engine platform.
3 better on exit bc of rear engine traction advantage on the loud pedal.
I agree w Joe, the 4 is more of a momentum car and will teach you more as you work your way toward faster cars.
I love my 4 and track it quite a bit but when I want to fly its all about the Lizard...
Cheers
Cheers
I own the GT3 now, but had both cars for a month before selling the GT4. So I conducted a few back to back experiments
My expectations were high for the mid-engine platform, but in the end I didn't feel there was significant advantage. I'm sure a professional driver could exploit all of its attributes, but I'm not at that level. My GT3 just feels more planted, add in the 4 wheel steering and it's magical. On sharp turns I would even experience some wheel hop in the GT4, zero in the GT3. In a similar sharp turn with an off camber transition and the GT4 was definitely more squirrelly. As we all know, corner exit is great with any 911, but it's sublime with the GT3. Both cars are great I just really love my GT3.
I think it’s also quite track dependent. Smoother tracks (camber, surface and corner layout) will flatter the GT4, at which point cornering performance largely comes down to balance and tire to weight. However struts show their limits as the suspension articulates, so basically anything that upsets the car. In those circumstances I find very obvious differences, and of course it’s those challenging bits where predictability is most valuable.
^^^^^this
Trade you my GT3 even for a GT4. Not...
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
3 has massive traction exiting the corners
whilst any similar torque mid-engine car can brake later when entering and slower on exit
RSR was flipped cause mid engine have rubbers extended life and easier aero (thst s why on street legal the Pista doesn t have an RS wing)
