Odd Rubbing noise in brakes 991.2 GT3
Hey there everyone, I know everyone has squeaky brakes, but I've recently been hearing an odd rubbing noise of sorts (in addition to the normal squealing); has anyone experienced this? I've posted something similar in the brake squeaking thread, but haven't a gotten response. Anyone have any ides?
Thanks in advance!
Thanks in advance!
Registered User
Usually means a tiny rock got in there.
Question - do you have PCCB or Steel Rotors?
If you are running steel rotors, then this is not an issue. I am not sure about how delicate PCCB's are as I never owned them.
I'm running steel rotors and it looks like you may be correct. I don't my car too often, but when I do, I drive on terrible streets in SF; as a result, I wouldn't be surprised if a rock got stuck in between the caliper and rotor.
I have over 10,000 miles on my GT3 now, and I've only had this happen once. I've driven on some pretty sh*tty roads, so once isn't bad.
Finally went to the dealership for a test drive and according to the Forman, the sound is not normal. I'll report back once they inspect it and let me know what the issue is. I'm hoping its nothing serious.
Basic Sponsor
It could just be the drilled holes in the iron discs. Drilled holes and slots in discs are designed to give the brake pads more sharp leading edges to grab. The downside to having all of those edges rubbing across the surface of the brake pads is a whirring or scraping noise. It's usually most noticeable when driving next to a wall or barrier, as the sound is reflected back to the ear.
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
![](https://rennlist.com/forums/signaturepics/sigpic110137_8.gif)
Jeff Ritter
704-824-6030
Thanks in advance!
Thanks in advance!
