"Fault, differential lock" meaning?
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,503 Likes
My transmission failed and the flywheel was badly damaged. Cost $19K to fix, Porsche didn't provide any warranty coverage or discount, despite only 38K miles on the car. Seems that the car wasn't truly built to last.
I have been concerned about this very issue. The GT engines and PDK have a history of Porsche replacement rather than local repair. This does note bode well for long term maintenance and longevity. Cost is difficult to assess. A top and bottom rebuild on an air cooled flat six can easily run $20K USD, but the people and parts are available to do the job.
And a top notch complete air-cooled engine rebuild is unfortunately well north of $20k these days (and a GT3 build would be a good deal more)...
Since the GT3 and Cup motors share almost all the same internals, it should be possible to buy Motorsport engine parts to rebuild a GT3 engine. PDK might be more challenging.
Valve Part Number?
Chad,
I recently developed the same problem on 2015 991 Carrera S. Intermittent issue. Error comes out intermittently. I just have to turn off ignition, then on. And it goes away.. Can you provide part number of valve that you changed? I want to show it my porsche dealer. Thank you.
Hello, sorry to hear about yours. It turned to be that the valve/breather of the gear is not working properly. It needs to be changed. This valve usually opens when there is a high steam in gear to release the steam or vapour but if it does not work properly then it will open not for steam but also for oil, then it will start leaking some oil drops underneath the gear. All the best
