Attention all .2GT3RS track guys....want input
For me:
Factory toe (0 front, 2mm in rear each side)
Factory caster
Factory height
-1.5 camber all 4 corners
front bar middle
rear bar middle
Max aero settings
About 25 track days and 10,000 miles.
Made no change.
I may fine tune sway bars and add some rear camber for Sebring once the car comes home.
Its that good out of the box.
Factory caster
Factory height
front bar middle
rear bar middle
Max aero settings
Made no change.
Same thing happened to me as well! Person in front of me went off just slightly and threw up a rock. Clearplex did nothing. Wasn’t even a big rock. Easier to just get the windshield replaced with insurance.
Even with more front camber the rears wear out two to one front set.
So might as well use up the edges and keep a nicer, less nervous steering feel.
Dunlops need a bit more camber then MPSC2.
For sure stick between - 1.5 and 2.5 max.
Martin, just run 1/3 tank, each session refill- More than battery weight savings. Or you can just fast and purge before track day- same.
Just saved you expensive kaboom and expensive battery for same performance- you can Venmo me the savings.
GT3 player par excellence
I told you not to use clearplex.
it is more trouble than none
What's the name of that black rubber looking stuff that you can spray on and then peal off later (I remember someone mentioned it on here a few years ago)?
