Racelogic VBOX; Anyone know Canbus cable 2019 GT3RS?
The induction harness works. It seems to be polarity specific. First time I tried it mine did not work. I reversed the wires laying in the induction clip and it started working.
- Chris
- Chris
- Chris
- Chris
anyone have pictures or instructions as to how they got the no-splice version working in a 991.2 GT3?
I'd appreciate it.
I'd appreciate it.
Hi Walter,
Connecting to the CAN Bus on any modern vehicle is fairly challenging these days.
You will need to connect directly to the CAN high and CAN low wires located in the main wiring loom. One of my colleagues managed to find these on a GT2RS located in the driver's footwell, above the footrest plate/trim. You will have to unwrap fabric tape to gain access. We are pretty sure these wires should match the GT3RS, but I am waiting for confirmation from our US office.
You are looking for a twisted pair - orange/purple and orange/brown. CAN high is Orange/Purple and CAN Low is Orange/Brown.
I hope this helps!
Jon Holman
Motorsport Product Manager
Tel: +44 1280 823 803
Email: jon@racelogic.co.uk
Hi Folks,
Just tried installing the clip-on cable in my 991.2 GT3 RS, but without luck. I tried between the door and fuse-box, as well as the connector going into the Continental gateway, next to the ODBII port. I tried reversing in both scenarios without any luck. Used orange / purple for CAN high, orange/brown for CAN low. See attached pics for locations I tried. It would be greatly appreciated if someone could post pics on where they attached the clip-on if they got it working in any of the 991.2 GT cars (3, 3RS, 2RS).
Btw, I assume you should see it working in the preview mode if all is fine? Also tried dumping the device logs from the VBOX to see if there are any hints, but unfortunately racelogic keeps the logs encrypted.
Connected to Gateway connector (disconnected in the pic)
Connected between fuse-box and door
Surely theres got to be an OBD WIFI connector these days?
Thats a shame really - the Porsche TPA is nearly there but not quite e.g. 10Hz data, video overlays that work seamlessly and instant read back e.g. go to pit lane compare runs graphically - reset go again. The only problem I've had is exporting to Circuit Tools - I can get the data across but not the video (although the later may have something to do with the CT CIR file being incorrect/outdated).
What I find strange is the output to USB through sports chrono is at 1Hz - go figure - Although the Porsche explantion would be from a statistical perspective e.g. if you do a 25 lap session at 2 minutes per lap you'll have 3000 data points which is statistically significant certainly for mechanicals e.g. temps, gears, steering angle, throttle, brake pressure etc. Likewise lat g, lin g and yaw rate. However, its insufficient if you're looking for a 1/10th here or there where lap by lap overlays at 10Hz min are required. Very easy to spot turn in and braking changes in subtle detail at this level of data.
Hi Folks,
Yeah, that was mentioned earlier in the thread as well. I tried to interpret what that means, so I flipped the clip-on around and see if that made a difference. Nothing. ProCoach suggested flipping the wires between CAN High and CAN Low, but no luck there either. Perhaps it's the clip-on module itself. It seems rather flimsy for a $300 cable.
i can not get the clip on to work in my 991.2 gt3 - and racelogic says it’s a know issue that it does not work - i have been successful with actual splices.
Anyway, I'll play around some more today and if I figure it out, I promise I'll update this thread with clear instructions for the next person that is going through this (Matt, are you reading this? ;-) ).
I waiting for the harness connector Racelogic is working on. BR Racing _IS_ my local installer as well - and I am the "issues" they have noticed
Issue: Every morning starting about 2 months ago my 911 now places a "Airbags Deployed" emergency call to Porsche Command Control -
THIS HAS NOT BEEN PROVEN TO BE RELATED TO RACELOGIC SPLICE INTO THE CAN BUS
READ THE LINE ABOVE AGAIN - THERE IS NO CORRELATION
the facts of the situation are as follows
1. I could never get the clip-on to work - after many many alternatives were tried
2. A "hard splice" does work fine and produced can-bus data - I have video from COTA where it was working
3. The can bus was working fine with no emergency calls for at least 4 months
4. nothing changed and the car started placing emergency calls when started in the morning - it "just" started happening
5. we have since disconnected the splice and the car still places emergency calls when started in the mornings
6. local porsche dealer has not been able to diagnose the root cause
7. the calls are placed only upon first startup in the morning - there will be 1 to 3 calls placed
8. Later in the day no calls are placed even after the car has been off/on several times
9. next day emergency call will be placed
10. I plan to drop the car off with dealer after track season for a more extensive diagnostic
11. You can request Porsche command/control "ignore" your airbag deployment warnings - I have done so.
12. It does not seem to be related to battery voltage state, as I have the car on a battery tender.
the mystery continues.
Can you share where you did the tap? The wires leading into the gateway connector, or near the fuse-box?
Quick update: After trying numerous things to get the clip-on working, including getting support from both ProCoach and Racelogic I decided to try the unterminated CAN interface cable instead. And with success! All is working now!
ProCoach prepped it with posi-taps, so installation could not be any easier. It took me 5 minutes to install the cable and validate everything was working. I tied it to the CAN-bus wires between the door and the fuse-box and routed the interface cable towards the glovebox. I'm planning to keep the VBOX in the luggage net in the passenger footwell keeping it secure using Velcro.
Long story short; if you're planning a VBOX install, do yourself a favor and purchase the regular CAN cable and install using posi-taps. High chance the clip-on won't work (even though Racelogic says it should just work ) and is actually significantly harder to install as you'll have to untwist the cable.
