Center Muffler - Broken Stud
I thought that since this has happened to me - it could happen to others. I have a 2016 991 GT3.
I removed my center muffler (CM) a couple of years ago and due to over torquing at the factory I broke one of the fasteners and stud when removing the CM. I thought the only eventual solution in going back to stock in the future was a new or used muffler. My conclusion came from researching the 991 CM parts catalog and finding nothing to help. Well, I found a that there is a part 997-111-727-90 that is a replacement stud. It simply screws into the CM. While some work is involved to remove the broken stud from both the CM and the fastener, the part cost less than $6. A few simple tools should provide the anticipated restoration.
Since I see so many folks seeking CM's, my feeling is this has happened to others and want to share to keep folks from throwing hard earned $$$ away.
rhk118 (06-06-2021)
What do you think would be the best way to get the broken studs out? An extractor bit? I have 2 studs that are broken. Thanks for the heads up and part number
- Apply heat to the broken stud on the muffler, assuming there is enough left to grip with a vice grip, which I have.
- After red hot, apply a simple candle wax to the stud, it will retract to the threads.
- Use the vice to turn it out.
- drill and use an extractor, however before extracting use the steps above.
Good luck
I also snapped two studs on my 2018 GT3 OEM CM when removing it to replace with JCR's Ti CM. Many thanks for this solution as i know its a very common problem...Why should be such an issue..?
Any updates? I broke a stud today. Ordered a screw extractor kit from amazon.
I finally got around to repairing my center muffler broken stud using part # 997-111-727-90 that is a replacement stud.. My planned approach did not work and I had to drill out the broken stud and tap new treads. If anyone is planning on this as a DIY, use a 7mm drill bit to drill out the broken stud. Be sure to use cutting oil and start with a smaller bit and progress to the final 7 mm bit, then tap it using a M8 1.25 pitch tap. Finished product is shown below:
rhk118 (09-11-2020)
Usually you tighten a little before you loosen to break the initial rust. Then combination of loosen and tighten the nut until it’s off. Lots of penetrating oil along the way too.
rhk118 (09-11-2020)
