Gt3 Touring high frequency dash vibration
Hello All,
This occurs between 4k and 5k rpm, and has become fairly loud and annoying. It seems to be coming from the gauge cluster or nearby, and is a high frequency plasticky buzzing. Can't find the source. Does anyone else have this? Any solutions other than dealer delving into it? Thanks!
The location doesn't seem correct for this but maybe check just in case- at about that same rpm range, one of the three buttons of my garage door opener (clipped on my visor) vibrates. It cannot be moving more than a tenth of a mm but it creates a very annoying buzz.
(I also do not use any keychains because of the buzz/vibration they create; to my ear, the thin single rings used by the dealer during a service visit are the worst)
I’ve got a similar noise at the same rpm. Mine sounds more like a heat shield vibration and seems to go away after 20 minutes of driving. It’s a GT3, so likely just part of the experience. It’s a lot quieter than the single mass fly wheel you get with pdk on the winged version.
AlexG911 (12-08-2020)
Possible causes, based on experience and being very sensitive to niggly sounds
- keychains, these rattle monsters should never have anything more than a piece of string attached to it.
- sun visors in plastic have driven me crazy in the past with teeny high pitch vibration at certain rpm. Wedge something between it and liner. Good reason to go with alcantara.
- seat belts have tended to create rattles so check that there’s tension.
I hope you locate the the source of your irritating noise. Until then you have my sympathy.
I’m also hearing a buzzing sound at the same rpms under acceleration. Vehicle still under 500miles
will repost with update when I have more miles.
Leather dash.
Seems to buzz behind the info screen or the tunnel.
Leather dash.
Hello All,
