Service Manuals
Have you considered replacing the bolts with studs? They come with torque settings in the instructions too ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
http://www.tarett.com/items/996-997-...csk-detail.htm
Don't forget the little studs for the brake line brackets too...
LOL, you must be reading my mind, Grant. Been looking at those studs over the last several weeks now. My concern is that you would then have to slide the caliper away from the studs. There is already quite minimal allowable caliper movement, even with the brake line brackets unbolted. Not sure if these would stress the lines too much over repeated pad changes.
Internet Exploder has a compatibility mode --> give that a shot.
Am I the only one that thinks it is INSANE to charge that kind of money for basic information?! I guess if it let me download the entire service manual $140 doesn't seem so bad but WTF!?
