DSCv3 Controller vs. 2018 GT3
what USB cable do I need for this - gonna buy a long USB cable to leave "hanging" on my roll bar so I can talk to the device with out crawling into the back again…
USB-A to USB-Micro or USB-Mini?
ok - I've ordered mine - I'll report my findings - thanks to all for your advice…
I'll plan to remove the passenger seat for install (since I have a roll bar) - any special advise for passenger seat removal - never done it - I have LWBS w/harnesses
thanks to @drdonger I've ordered a long USB cable so I'll just leave it dangling for easy access for firmware updates and what not
I'm guessing I'll need a windows machine to talk to the box?
anyone have thoughts on storing the OEM controller?
Premium Sponsor
USB-Mini. Its the same connector as for GoPro.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
For seat removals, need E sockets or E Torx, then easy
https://www.homedepot.com/p/Husky-1-...13PC/206031060
Premium Sponsor
Thank You Sir. We look forward to your feedback.
You'll need a E12 socket. There are four bolts that hold the seat rail to the floor. Slide the seat to gain access to those bolts. The two bolts on the front are covered by plastic trim pieces, they pop off with a small flat blade screwdriver.
Disconnect the negative terminal on the battery. Unplug the large yellow connector under the seat.
Once he seat is unbolted the way to take it out is tilt the top out of the cabin first, then lift the seat out. I recommend using few layers of masking tape on the door sill to prevent getting scratches from the bottom of the seat rails.
Yes, the DSC software requires Windows7 or 10. If you don't have a Windows PC and don't mind having a used PC then I've found this company(link below) have good deals on refurbished PC's. I have personally bought three PC's from this company that I take to the track for video, data, DSC, and Durametric use.
https://www.blairtg.com/daily-deals....orm_factor=603
I would store the OEM controller inside the supplied DSC protective box. Away from moisture of course.
Super big thanks for the answers to the specific questions
e-torx ordered!
10 ft USB cable ordered to leave out for quick/easy updates and configuration
i have VMware for my windows machine simulator so I’ll use that!
can’t wait to try this device out!
e-torx ordered!
ok - we're installed - man that's a pain in the *** with the GMG roll bar - but it's installed - only thing is I can't get device to show up on USB bus - but it might be my cable
Question: does the device come ready to use with a baseline for 991.2 GT3 - or do I have to actually get it to connect to the DSC software and do an initial install - PSAM button works as expected - no noticeable differences as of yet - but we'll be testing at Laguna Seca this weekend!!
Did you attach the DSC to your PC before installing, did it work then?
In the DSC software, did you try selecting each COM port? I recall using COM 4 when I had a DSC V2.
Your new unit will have the latest software (Dec 2107) for "Porsche GT cars". It seems that it uses the same file for the 991.1, 991.2, GT3, and GT3 RS.
I'm very interested in how you get on with this and any other comments from 991.1 GT3 owners, I have a 991.1 GT3
I realize that autocross is not the same as DE. A lot happens in a 70 second autocross and the turning, braking, acceleration is rapid fire.
That said, I liked the DSC controller in non-sport mode. The suspension felt the same but the harsh ride over bad pavement was noticeably smoother.
Interesting thanks.
PS I did set up my old 964 RS with Motec using throttle position and sensors for the map. I do like the idea of being able to adjust and set it up how you like it, but not sure how user friendly this is (I have set up bump and rebound dampers before, but a lot of trial and error)
Curious how those that have gone the DSC route are feeling about it on 991.2s specifically? Just took delivery of mine last week and putting some thought into this. Have always been curious but don’t have direct experience it.
