Front License Plate Mounting Options
DD now is the 991.2 GT3 - wish the curvy stretch on Mt Pleasant through Rosedale was longer! When weather is bad/cold, I drive my 2018 Audi RS3 or sometimes my wife’s 2018 Velar HSE R-Dynamic. Panamera and GL are gone.
Originally Posted by GrantG
Quite a few of us are going without. Here in Denver, it is only an issue in the event of leaving the car parked on the street (not a moving violation, afaik). If I wanted to use one, I would probably get one here:
http://www.usmillworks.com/
Do the grill openings become bent and deformed from the spring loaded hooks holding the plate?
I've considered this "Carbonio solution" but am concerned about it's long term effects.
The Cooling system is laid out to function with the central cooling intercooler at full airflow. Might lead to too early overheating of the car.
US Millworks on both.
3M Automotive Trim Tape. It's what Porsche uses (well the method if not the actual product) to mount your front plate during Euro delivery. Comes off clean with no residue. Can mount at any height or location the plate will lay. Can curve to bumper. Can remove and reinstall easily. Cheap.
I have a carbonio front plate and it's great. I recently took it off to see if I'd get pulled over here in NY (primarily drive in New Rochelle and the Bronx) and I got pulled over yesterday while parking. I suspect I wouldn't have been pulled over had I not slightly sped through the local road but the cops let me off with a warning luckily. I feel like if you just have the plate in your car and just say you'll put it on when you get pulled over - you won't get ticketed.
No. Thought those were your coworkers' cars. Why all parked underground? I also have a Velar. Bayview/Mt.Pleasant around Rosedale are snippets of good driving roads.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image1_3707b067e06fe4833b232f5a75d0030e2d604bfb.jpeg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image3_69a886b4b1fd4ad0f8cd9128cef4ee12c66c0f22.jpeg)
