Michelin Connected Tires
In Track mode the McLaren 570s shows pressure and temperature on the display. We all know how important the pressure is, and I look at the temperature as a relative value. After a run the tires will tell their story anyway.
Received 1,257 Likes
This is indeed interesting. TPMS measure both pressure and temperature, even Porsche TPMS, Porsche just chose not to display that temperature, but they take it into account when recommending how much air to add or remove from the tire. I can see why Porsche chose to not display TPMS temp reading because it's air temp and not tread temp, so it's kind of misleading and not particularly relevant when you know the pressure.
this is very very cool. most of the time we're just guessing how much pressure to remove.. this is taking a critical area of the car's performance envelope, and turning it from a guessing game into science. better for wear, performance, safety.. Ferrari already offers something like standard.. but now to be able to do this in any car.. A-MAZING. game changer.. i know what tires i'm buying next.
What do you mean by that? If you use the pressure gauge to check tire pressure, you know exactly what the pressure is, so you know how much to remove to hit the desired PSI. Or did you mean that the desired PSI was not always clear?
I am not a mechanical engineer so I apologize for the drawing, but it looks like something like this
What about secure mounting so that it doesn't come loose within the tire/wheel combo after running over kerbs or mowing grass (tire flex).
A lot of questions will still have to be addressed for me to commit to only running that tire on track.
P.S.
Murphy's law states if there is a way for a screw or nail to find that sensor location on first try it will.
[QUOTE=ExMB;14914524]I can't see imbedded filaments in one section of the tire inductively read through the sensor based on what was shown in that video including actual location.QUOTE]
I have experience with similar layouts in sailboats, in AC, TP2, VDG, VOR, ORMA, IMOCA etc..
We lay fiber optics in between the carbon layers and we measure (based among other things on resistance and db loss) torsion, compression, expansion, and temperature. in the sailing and aircraft this has been done for years. We had between 100 and 600 strands (fibers) in each run. here we are talking 5 if I understood correctly/ BTW I have no horse or donkey in this race.
Anyway, those are virtually inflexible structures compared to a tire. You cannot translate between these two and make statements that to those unfamiliar sound authoritative.
I'm not sure what aircraft you are talking about but if you are talking about instrumenting during design phase versus production and equate you are at the deep end IMHO. Even if you used fiber optics you would still need to terminate to sensors of sorts since fiber optics will not do what you imply.
I guess that I (and a lot of other designers and engineers) have been in a deep end helping to design winning boats and measuring all kinds forces in sailboat hulls using fiber optics (not the one you would use as a carrier) for about 10 years. But I am not going to get into a dissertation in a web forum.
Unsubscribed
Guys don't over think this lol... By guessing, I'm saying without this device you have to try out different pressures until you find that sweet spot. You could just use a rule of thumb setting like most of us do including me for the most part but it really varies based on conditions. 60 degrees and wet vs 90 degrees and sunny will produce very different results with the same pressure. Also 20 minute or 40 minute session? More left turns or more right turns? This device and app while in its infancy seems to be a key for optimal tire performance that goes past any manufacturers system in a road car.
