CL track torque
I seem to remember that the 997 CLs were supposed to be torqued to 600 ft. lbs. for track work but I can't find any similar spec for the 991. Am I just imagining this or is there such a spec? TIA
but it's newton meters , 600 nm of torque = 442..54 foot lbs.
I set wrench to 450 ft lbs , remember wheel needs to be unloaded , not carrying car weight !!
manual states to tighten to torque , then back off a 1/4 turn and then re-torque to click ,
then drop that corner off the jack
info/procedure is in your manual
I'm familiar with the standard procedure for street use and know the difference between ft./lbs. and Nm. There was a TSB from Porsche back in 2010 that recommended higher torque for vehicles used on the track and that the customer should be advised before using the car on the track. I know the 991 CL is not the same design and I'm wanting to know if there is any information from Porsche regarding the spec for use on the track for this version.
For the 991 CL's, the workshop manual does not specify an increased torque spec for track use. Also, the race circuit addendum that came with my car calls out specific requirements for maintenance, tire pressure, and other items but there is no mention of increased CL torque settings. FWIW.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/686x876/race_tsb_07207d64da14a2eb669ddbb88d3f8fcadf632bf4.jpg)
They claim it's a better design now. Still 5 > 1.
Then at 442 ft/lbs the torque requirement for the 991 CL's is already much higher than the 997's street spec. In combination with the other improvements to the 991 CL wheels, bearings, and hubs, I suspect that the 991's standard spec is appropriate for both the street and track.
