White smoke gt3 991.1
This is new to me. I turnned the car on went to grap my phone as i left it in the house. Walked into the grage and i thought something is burning. The whole gatage was covered with white smoke !!!!. I immediately turned the car off. Went to look at where this smoke coming from.
It was shooting out of the exhaust.
well i dunno whats wrong someone maybe can inlight me please. But let me give you brief abiut previous days so you get the whole picture here.
it is 14 gt3 with 22k miles. Two weeks back car kept given me an alert of low oil and i should top up. It comes sometimes and sometimes itdoesnt. So i said better be safe than sorry so went and got mobil 1 oil and top up 2 bottles. 2 ltrs. Then started the car the car says warning yellow mark that oil is above limit but possible to drive. Drove the car around then i had to travel for 5 days. Came back and today i started the beast everything in order started with a yellow message of the oil being above avarage. Got the right temp to drive . Took my kid to his martial art class 10 minute drive. Then on the way back we where in sport pdk and driving home having fun with rpm above 5. 15 minute drive and stopped the car. What happen next was what i explained in the first paragaraph
The oil volume from min to max is 0.8l or 0.2l per division bar. The manual also recommends not to add more than 0.5l at a time, then check level. If you added 2 ltrs, that is too much and it is overfilled. That said occasional smoke on startup is not unusual.
should i reduce or flush and change oil ?
No need to change the oil unless it's due. The manual strongly advises not to overfill. The recommended optimum level is 3 bars. If overfilled the manual says to have the oil quantity corrected at the next opportunity. Also to adapt driving style, whatever that means. So if it were me I'd drain some oil and get the level right. I had the dealer do the first oil change on my 15 GT3. It gave the overfill warning when I picked it up. I refused to accept it until they drained it to the 3 bar level.
This is an extremely sensitive aspect of the car. I would not drive it until excess oli was removed. You can loosen the oil filter to drain oil out, or take it to the dealer if they are real close. Maybe best to let them sort it out.
Crazy gauge. Dipstick please?!
They should just go back to a dipstick. Simple and it works. This is a case of technology causing more headache than it solves.
Ok gd news . I drained some of that oil . It smoked less and less then it went away. I drained almost 2 ltrs. It is not due for oil change yet . 2800 miles till next service. After draining yellow message still pops overfill oil. Shuold i drain more !! Or drive for a while and see if it disappears??
