PCCB rotor stuck to hub
Hi Folks,
I can use some help here. First time "mechanic" here, and I'm trying to remove one of my rear PCCB rotors from the wheel hub so that I can measure it. I removed the wheel, brake caliper without problem, but for some reason the rotor will not come off the hub. It wiggles a bit, but it appears to be stuck at one of the bolts. Not sure how much force I can use either. Any suggestions are greatly appreciated.
Originally Posted by urban2k
Yep, they were on very loose.
You can see the blue drum parking brake in this photo.
The parking brake may make a difference on the rears. Take the brake off and see what happens.
When you measure the density of the disc make sure they are on a solid piece of wood to get the most accurate reading. There are three reading points on each carbon disc.
Parking brake has to be off to remove rear rotors
Thanks! Once I get home I will give this a shot! Quick question here, if I disengage the parking brake I need to depress the brake pedal. Should I first mount the caliper back on the rotor? I'm concerned I won't be able to open the calipers in the future if they fully close.
Yep, thats the plan. If I can get the rotor off, I'll be measuring them on Monday. I'll post the results in the other PCCB thread.
I tried that once (rubber mallet) - didn’t work
I tried for a long time before remembering to release the parking brake on an old 911...
Those little parking brake shoes have quite a grip (especially if there’s been a groove worn in the rotor hat over time...)
It was indeed the parking brake. After disengaging it, the rotor came off effortlessly. Thanks for all the help!
