Morning drive Manual GT3
#31
Never had the wherewithall to try power shifting before, but after reading this thread played with it a bit this am. Very fun! Doubt if I'll be doing it routinely, though. Seems as if it can't be real good for the gearbox and clutch.
#32
From what I understand it's nothing mechanical. The car's software is managing the throttle for you. So even though you've got it floored, the throttle body probably isn't open. So it helps reduce shift times because you don't have to physically let off then get back on the throttle, the car is still doing it. It's just doing it for you. But I'm just guessing.
#33
#34
#36
@OP did you try power shifting at redline with traction control fully off?
Did you try turning on sport mode but turning traction control fully off and see if it still blips for you?
#37
Yes i tried traction off and in low gears i can still see traction control light between 1-2 and 2-3. Didnt have a chance to turn traction and stability off but i would think it will spin the tires between those shifts.
Sport button didnt really change anything on up shifts at redline. If made for smoother up shifts at lower RPMs only. Of course the main benefit is rev matching.
#38
If its shutting down throttle between shifts i would feel it for sure and it wont trigger traction control intervention. Sport button does control engine speed for sure. So that what they mean maybe, but not at 9000rpm up shifts from what i experienced.
#39
I'm very jealous- if I was caught doing that in the states, I'd be in jail.
#41
Ah, thanks, I thought there would be a good chance there was a difference between the bikes and the car, thanks for clarification.
#42
Originally Posted by LSs1Power
Can an Aussie match the camel crossing with a 'roo pic?
#43
