"Clubsport" build underway
#136
Over a three-day event I put nine heat cycles on Trofeo Rs and they were just as fast on the ninth as they were on the first. I had Tire Rack heat cycle them prior to shipping to see if that would help the longevity and the jury is still out until next season.
#137
I'm running Trofeo R on the 991 Turbo S right now.
There have been at least 3 different compound/construction batches of Trofeo R since 2014.
On the track, they stick with similar levels of grip to the Hoosier R7. I run them at 28 front and 30 rear, -3.5f/-3.0 rear camber (my TTS springs are stiffer than my RS springs). Trofeo R require a lot of camber, the compound is the same across the tire, not the hybrid MPSC2 or worse 2R.
They are grippy, avoid them in the rain. This is my set #6, 3 days is all I get, I had to switch to a non-Hoosier in the TurboS, due to cording the rear Hoosiers in 2 track sessions (RWS with twice the turning angle could be a factor here).
However, don't expect a set of Trofeo R to give you a 2:10 lap time around NCM, it's not going to happen. Also don't expect a set of scrub Pirelli slicks give you a 2:12 lap around Sebring in a .1RS, not happening either.
#138
#141
FYI - I've already run multiple 2:10 laps at NCM on Trofeo-R. See above AIM. I did it pretty easily actually, not even trying for fast laps, as a 2:09 is definitely do-able.
#142
My shop installed them and don't use a PIWIS. Also, same protocol provided to me by Emotion.
#143
I can totally see why all the mags raved about the RS, as it has monoballs everywhere, and it's def. a big upgrade for the track.
#144
Thanks, I previously ran -3.6f/-3.0r on Cup2 and it was too much, so backed it down a little bit for testing Trofeo. Will likely bump it back up a bit.
By the way, the overall fastest lap at the Inaugural SCCA Time Trials National Championship last month was a 2:08.6 by a Viper built for SCCA Club Racing. You can run Hoosiers and slicks in the Unlimited class, all other classes require non-ACR 200TW tires.
Link to the near 200 drivers results>>> https://timetrials.scca.com/events/1...ssions/overall
#145
Hence my observations. Don't expect the public to repeat a proven performance formula by MVez, Orthojoe or Trakcar and obtain the same results. Nope, not happening.
#146
Lots of cars ran Unlimited without a cage at the National championship. I skipped the event because my GT3 is cage-free. I have a pending letter to them, as I'm not keen to run on 200TW tires, so any decent street tire with less than 200TW and any decent track tire sends me to Unlimited. If they want to grow the program, that rule needs to go away. We might see some changes in the ruleset along these lines this coming year, as that requirement came from the SCCA Club Racing folks that are growing this new program.
Locally, I ran with no cage, and told the local officials that requirements for a cage would eliminate more than 2/3 of the typical track day and DE enthusiasts as they use track-oriented tires that sit at 180TW or less.
Trofeo-R are my favorite drive-to/from track day tire, and it is nice to have the option to run Trofeo-R without bumping into a class that is intended for factory race cars, NASCAR road course cars, and lots of other pure race cars.
Question on Ohlins (I'm considering them as my next mod):
Can you adjust compression and rebound without removing wheels, or jacking up the car?
Does Ohlins provide a baseline setup for compression/rebound?
Does Ohlins have chassis engineers available for hire to setup the shocks for a given racetrack?
thanks,
thanks,
#147
thanks,
thanks,
Yes, you just turn the wheels and adjust. The rear you either lay on the ground and adjust or I just jack up a slight bit and makes it even easier. Very easy in general.
Yes, they provide a baseline setup that is very good. I'm literally within 1-4 clicks of it at all times, even on DH slicks. 1 click in either direction makes a noticeable change.
No, they don't do that, and you don't need to. They spent a ton of road/track time developing these shocks for the chassis, and the fact that they continued to adjust spring rates tells you so. The current setup with baseline settings is honestly all you need. It's amazing right out of the box, and will work for virtually any track, with maybe a click or two in either direction.
#149
315-705-19 rear
Perfect rolling diameters. Fit perfect on 9" or 9.5" front, 12" rears. No changes needed between stock 20" wheel ride heights or setup. These are the current Ferrari challenge sizes.
#150
They are like crack. Difficult to go back once you've run these.
