991 GT3, GT3RS, GT2RS and 911R 2012-2019
991R vs 991.2 GT3 Touring
Old 12-28-2017, 06:58 PM
  #241
Footsoldier
Footsoldier's Avatar
From here:
Old 12-28-2017, 07:29 PM
  #242
Oldmxnut
Oldmxnut's Avatar
Originally Posted by Apolo1
Using the above time differences for the GT3.2PDK and 991R over 100-200Kph, on a V-max run to 300 Kph, I would put the GT3.2PDK to be around 60 Mtrs at least in front of the 991R.
How are you finding the set up on the GT3.2. To be honest I have struggled a bit, adding to much rear Toe did not help, just made the back end snap out, when the same part section of track the 91RS just had grip and more Grip. Think its sorted now , well at least it gives me the confidence to drive at 10/10s. Feels very good on the road also.
Front Ride - 15mm
Rear Ride -12mm
Front Camber -2.45
Rear Camber - 2.15
Front Toe, Stock
Rear Toe, Stock
Shim Part Nos
996 341 543 91
996 341 543 99
Thanks for these reference points. What's your thoughts on the set up for a touring version. Start with same or change slightly for a starting point. ?
Old 12-29-2017, 12:49 AM
  #243
C.J. Ichiban
Platinum Dealership
C.J. Ichiban's Avatar
Received 1,958 Likes on 556 Posts
The more ride height, the more the car will squirm...so- how loose do you want your caboose?
Old 12-29-2017, 05:16 AM
  #244
Apolo1
Apolo1's Avatar
On a GT3T, I presume that you don't have tracking to much in mind? like the chaps says above. I would just start with ride height and stock settings set to the outer limits. Along with correct tyre pressures.
But one point that is very important on RWS cars, is that Steer ahead is set to 0.00. I have had many RWS 991s that this is out on. In my experience it makes a big difference to the way in which the car drives.
Old 12-30-2017, 08:13 AM
  #245
Oldmxnut
Oldmxnut's Avatar
Thanks Gents, makes sense. Intend to continue to tick off a few track days and a few targa's each year regardless of being a touring. I'm not expecting RS level dynamics but do like the confidence feeling of the rear end holding tight at 9/10th. So potentially less loose a caboose... Steering 0.00 noted.
Old 01-05-2018, 01:14 PM
  #246
MerlinsGarage
MerlinsGarage's Avatar
Cool
Thanks CJ, riscan, Oldmxnut (et al) for the hands-on experience.
................................and to Mr Rouleau for calming the vibe.
The GT3T is exactly what I had hoped it would be. Relative to the R.
The same.....but ah (slightly) different.
Now to pick a color. PTS would be nice
Please carry on
Best,
Bret.
Old 03-19-2018, 12:43 PM
  #247
Perimeter
Perimeter's Avatar
Are 911R prices softening due to GT3T deliveries?
It seems that 911R prices started with a "4" before 2018 and now they seem to start with a "3" ?
Old 03-19-2018, 12:51 PM
  #248
Jimmy-D
Jimmy-D's Avatar
Received 1,399 Likes on 725 Posts
They have softened a bit but will stay starting with a "3"; unless it is PTS with CXX ect ect
Old 04-02-2018, 07:39 PM
  #249
MerlinsGarage
Jimmy, have to agree with your pricing thoughts although higher mileage examples may see a discount into the 2's in a few years.
Nonetheless the vacuum left by the R should be satisfied by the second bite of the apple - GT3T.
Given a choice between ordering a new PTS GT3T or used R I would, (will) have to go with new.
Just MHO, but it's my Frankenstein..............
Old 04-02-2018, 07:50 PM
  #250
MerlinsGarage
If production continues and eventually get an allocation maybe the Sport Design Duck Tail will be available.!!
Old 04-03-2018, 03:12 PM
  #251
Jimmy-D
Jimmy-D's Avatar
I agree- I would take a configurable T over a used R all day
Old 06-16-2018, 08:17 AM
  #252
Brian Himmelman
Brian Himmelman's Avatar
Originally Posted by _fletch
Is this correct? A quick check on google found GT3 MT was 1413kg (3,109lbs) and R was 3,021lbs making a difference of 87lbs. TBH I actually thought it was a bigger difference (like 180lbs) but 87lbs is still quite a lot.
if you spec the 991.2 Touring with PCCB'a and LWB's the difference is approx 20 lbs
Old 06-16-2018, 08:27 AM
  #253
Brian Himmelman
Originally Posted by fxz
between 62 and 124 mph driver changes 3rd and 4th gear to upper ones
most likely the wingless .GT3 T manual with less drag and less weight than .2GT3 wing and pdks, should keep the same 7.7
sport auto doing tons of testing should balance with fuel the eventual driver diff and for sure these times are not from a single but the best from multiple attempts
i"d still wanna put a couple of RS bmc air filters on The .2GT3 and repeat the test...
not to mention a permissive 997 RS exhaust....!
can you confirm if BMC filters actually create real world performance improvement ? Just decided whether to purchase .. thanks
Old 06-16-2018, 11:04 AM
  #254
_fletch
_fletch's Avatar
This has been discussed elsewhere. Porsche's practice was to list the weights as specced with the lightest components so in the case of the Touring that would presumably already be with the PCCBs and LWBs. As you know this is all changing and the manufacturers will need to list these specs for every configuration going forward.
Old 06-16-2018, 11:21 AM
  #255
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
It was discussed in other threads (one of which I started and has a title about being a lotus owner) and with help of some info from 000/Peter Stout and Petevb and others we got very close to the right answer, but basically it was the lithium ion battery, ti exhaust, cf fenders/bonnet/roof/rear engine cover and SMFW which were the main differences for identical spec cars. The lightest spec is the headline published weight, but because the GT3 is not available with lithium ion battery, AC delete and was initially not available (when the weight was released) with radio delete (this point is not 100% confirmed as to the headline weight), the difference in weight between an R and a GT3T of the same spec is not that much.
Quick Reply: 991R vs 991.2 GT3 Touring
