Sport Chrono on 991.2 Manual Transmission
SJW, a Carin' kinda guy
So with sport chrono you get the mode selector on the steering wheel, sport plus and individual as opposed to just sport on the console?
Can you configure rev matching on downshifts without sport being on with sport chrono? How about without?
I went through the threads on sport chrono but no answers for MT (which makes sense as it does not exist).
How does it work on the 911R?
On GT3, GT3 RS, R, Touring and also GT2 RS all whether on a pdk or manual car you don't get the mode select on the steering wheel. Actually you don't need chrono for the modes as there is only normal mode and sport mode, which is activated by a button on the console
For manual once you engage sport mode it will rev match for you but if you remove TC even with Sport mode on then it won't rev match for you anymore unless they changed that recently
Basically the chrono is just a clock / timer and i think works with the app. Many here find it an option that is useless since mostly everyone prefers harry's laptimer
So the configurator is just wrong?
The Sport Chrono Package adds numerous features for sport-oriented drivers:
Analog and digital chronograph – a chronometer installed on top of the dashboard can be used for timing laps, and can be configured as a clock when not actively used as a stopwatch
Mode switch on the steering wheel – vehicles without the Sport Chrono Package feature Normal and Sport modes, selectable via a SPORT button on the center console. Adding the Sport Chrono Package moves the SPORT button from the center console to an additional mode switch on the steering wheel, allowing drivers to select from multiple drive modes (4 with M/T, 5 with PDK):
Normal mode
SPORT mode
SPORT PLUS mode
Individual mode
SPORT Response (only in conjunction with PDK)
PSM Sport mode – briefly pressing (< 1 second) the PSM button in the center console activates the PSM Sport mode. In this mode, the driver can push closer to the limit range of the vehicle while PSM remains constantly active in the background. PSM Sport mode can be activated independently of the selected driving mode
Launch control – the launch control function manages the engine, gearbox, and stability control systems to provide the quickest standing-start acceleration. This function is only available on vehicles equipped with the PDK gearbox
Rev-match function – in conjunction with Manual Transmission, the SportChrono package provides a rev-match function in both SPORT and SPORT PLUS modes, matching engine RPM to transmission speed for smooth downshifts
Porsche Active Driveline Mounts – In Normal mode, magnetorheological driveline mounts remain soft to minimize perceptible vibration of the drivetrain. With SPORT mode switched on, the mounts stiffen for driveline dynamics suiting a sporty driving style. With SPORT PLUS mode switched on, driveline mounts stiffen further for maximum performance
Included in configuration
$550
Normal mode
SPORT mode
SPORT PLUS mode
Individual mode
$550
i'm confused as well, i thought it was just a clock on the GT3 but when they added the touring package they added a sport chrono option listed above. AND the description suggests it doesn't come with rev-matching without it..
Before the Touring option was added Sport Chrono wasn't an option i don't think..
Looks like somebody screwed up. Maybe when they added the touring options. The GT3 just has one engine map, it's always on speed. Not like the non GT cars that need modes.
Originally Posted by Larry Cable
interesting, I wonder why they decided to do that?
Originally Posted by carrering
If you can have rev matching off with sport mode and tc off thats perfect! i would rather have it permanently disabled. its a manual!!!!!
Chrono is separate, and only added the clock etc, no performance options, so I didn't bother with it.
Originally Posted by Footsoldier
Yes, the only thing the sport button does on an R is to switch on rev-matching. I never use it!
