garage car lifts
#316
#317
That looks so much cleaner without the extra posts! What’s your ceiling height?
#319
What brand is that single post lift?? Very clean.
#321
#322
#323
^^^Thanks. I had no idea something like that existed.
#325
For the single post guys, is basic maintenance doable? Can the car be lifted off the tires while on the lift? The single post makes by far the most sense for my smallish garage, but I've resisted due to perceived uselessness when it comes to maintenance.
#326
http://radliftsbygemini.com/portfoli...g-bridge-jack/
Would be interested to get feedback if anyone has one/similar device.
#328
I've not performed any maintenance with the cars on the lift as the weather has been too cold since they've been installed. For wheels-off maintenance, I found this bridge which straddles the runways:
#329
i have something similar for my 4 post lift. They work great but a little inconvenient as you need to add extender arms to get at most car jack points. Other than that, you need air supply as manual version to lift car would be a nightmare to try and do under the car. Has been useful when needed. Will be using mine to do brake fluid change so I can remove wheels when on the lift.
#330
[QUOTE=Kama_Supra;15741097]You need to get a high-lift kit so the doors lift up and over. No need to change the garage doors themselves.
[/Q
UOTE]
I did not need to get a port o john to have my high lifts installed. What part of the country are you in? What were the terms?
[/Q
UOTE]
