991 GT3, GT3RS, GT2RS and 911R 2012-2019
Battery Maintainer?
Old 12-21-2014, 10:07 PM
  #46
WSH
WSH's Avatar
Why connect to battery/through the frunk when you can just plug-in to the cig lighter ??
Old 12-21-2014, 10:09 PM
  #47
doubleurx
doubleurx's Avatar
Originally Posted by rockitman
There are 3 sizes...M6, M8 and M10 I'm not sure what size comes with the combo kit. Maybe someone can confirm the metric size of the bolts on the battery where the eyelets would attach ?
Pretty sure it comes with M6. I had to snip mine to a "C". In order to fit. Still works fine.
Old 12-21-2014, 10:11 PM
  #48
doubleurx
doubleurx's Avatar
Originally Posted by Mike in CA
Nick, one of our RL buddies (mcsmcs1) followed up with an e-mail to Banner, the Austrian manufacturer of our OEM AGM batteries. They confirmed that the snowflake mode on the CTEK charger is the right one to use. Have fun and be safe on the slopes!
Thanks Mike. Ended up not going due to all the crowds. Went on a hike with the wife for a couple hours, then relaxed with beer and wine. Great day all around. Looks like it may get warm enough to take the GT3 out for a spin and wash!
Old 12-22-2014, 02:29 AM
  #49
Mike in CA
Mike in CA's Avatar
The bolts you'll want to attach to have 10mm nuts. When I bought my extension cable I didn't realize there were different size eyelets available. Like doubleurx, my eyelets were too small so I ended up clipping the ends to turn them into spade connectors.
I keep my cover in the frunk so I'm in and out of there whenever I use the car. Since I'm already there anyway, plugging up the connector in the frunk to my charger mounted on the wall nearby is a snap. It's further and less convenient getting inside the passenger compartment to the cig lighter. I'd need an even longer cord or have to drag the charger around. YMMV.
Old 12-22-2014, 02:54 AM
  #50
rockitman
rockitman's Avatar
Thanks Mike
Old 12-22-2014, 03:07 AM
  #51
Mike in CA
Mike in CA's Avatar
Thanks Mike
You're welcome, Christian. Do you know what the M6, M8, and M10 refer to? If 10mm is the overall size of the eyelet you're probably ok but if the opening in the eyelet is 10mm it might almost be too big.
Old 12-22-2014, 06:14 AM
  #52
joaobraganca
joaobraganca's Avatar
Don't know if it helps but according to their website:
M6 - Eyelet: M6 (6,4 mm)
M8 - Eyelet: M8 (8,4 mm)
M10 - Eyelet: M10 (10,4 mm)
Old 12-22-2014, 10:50 AM
  #53
fastmd
fastmd's Avatar
This^^^. Buy the adapter for Battery tender and done. About 2 second install.
Old 12-22-2014, 11:06 AM
  #54
rockitman
rockitman's Avatar
so you think the M8 size would be the best fit if M10 is too big ?
Old 12-22-2014, 06:00 PM
  #55
Mike in CA
Mike in CA's Avatar
So is that overall size, or the hole in the eyelet, or does it say?
Not knowing what the sizing measurements above refer to, I don't know how to answer that question. No matter what size you get you can probably adapt by clipping the eyelet or using a washer.
Old 12-22-2014, 06:20 PM
  #56
Clocked
Clocked's Avatar
FYi, just picked up my GT3 or should say I saw it. The dealer is storing my car for the winter. Went and saw it and dealer put the battery tender on and did it via the cigarette lighter.
Old 12-22-2014, 06:24 PM
  #57
Hothonda
Hothonda's Avatar
Decided to try the Deltran Battery Tender Jr I already have for my big lawnmower battery ($30). Used it for years.
1st time on the 991 took overnight for the red light (charge) to go green (maintain) using a
$5 cig lighter adapter in lieu of the battery clamps. Now instead of 14.8 V when I
start the car from cold, it reads 12.4 in the dashboard gauge. To get to full charge now (green light) takes about 1/2 hour.
Works great & I bought another ($30) to put back on my mower.
Old 12-22-2014, 06:46 PM
  #58
MJones
MJones's Avatar
Question:
Does the cig-lighter work when the key is removed?
  #59
Hothonda
Hothonda's Avatar
Originally Posted by MJones
Question:
yes
Old 12-22-2014, 06:54 PM
  #60
KenU
KenU's Avatar
Congrats!!
Quick Reply: Battery Maintainer?
