Newbie CL question
#64
I agree it is worthy to be familiar with the process but to claim the Porsche dealership do not know what they are doing is a stretch. I do not plan to switch tires for track events. Any work done on the CL's will be done either by my dealer or someone who I believe knows what they are doing.
I am not track junkie and not handy with tools and I will leave the mechanically work done on the car with people who are trained to do it.
#65
I've got all the tools now, including the 3R tool below and specified grease. My only question is, how much grease to use? On the cone and threads. A little or a lot?
#67
I'm with Nick, you shouldn't have to be a "shade tree" mechanic to make sure that a 2014 car operates safely.
#68
Unfortunately, that is not the reality. If you can't do it yourself, make sure you find someone you can trust. Blindly trusting work being done just because they are a Porsche dealership is a mistake.
#69
If you plan to track or drive your cars hard in canyons, backroads, etc. then you are insane to not know and practice proper wheel torque and maintenance.
#70
For the 997.2, the threaded areas required a thicker (0.5mm+) coat of grease, the conical areas and those within the bolt a light coat (0.2mm) or enough to lightly coat as 24Cr suggests.
My suggestion, when you pick up the car, ask the dealer to provide a print out of the workshop notes applicable to the 991 CLs so you can be certain...
#71
GT3 player par excellence
reality and fantasy are not the same..
i dont have to be shade tree mechanic, i became a real mechanic
you will wake up once you have a CL car.
it's like airborne rangers. they ALL chk their OWN chutes. you dont leave that to others.
#72
Actually, I had a CL car and now it's gone but that's a story for another day. I didn't say you DO NOT have to check your own CL's, I said you SHOULD NOT have to be a mechanic with special tools to check them. With five lug wheels, I, and I assume almost everyone else in the world, drive away from the dealer without worrying about the wheels. When I go to the track, checking the lug nuts is a simple procedure with a basic tool that everyone understands. If you read my earlier post in this thread, you would see that I questioned the purpose and value of CL's. This lengthy technical discussion only confirms my opinion.
#74
I'm pretty sure the manual procedure for the 991 was posted here and I don't recall it stipulating the amount of grease or that the bolts needed to be disassembled as was the case with the 997.2...
