GT3T with PSE on vs off
Three clips. One at idle. One at 120kph and another at 140kph. All film on same road at same time. Car runs Dunlop’s.
You can heat that at idle there is a distinct difference. But notihng at 120 or 140. Indeed the sound at 140 is very unpleasant.
Funny i just posted this on another thread. I actually didn’t know the PSE button on the GT3 actually did more than just noise. Other cars I’ve had it was just noise. Default should be PSE on, with a button to turn it off!
I think the valves open whenever you push the button, and if left closed will open automatically above 3,500 rpm. So, the engine should sound the same above 3,500 rpm. Below that rpm, it may sound different outside, but the important thing is the increased low and mid-range torque with the button pushed.
You do realise Chris that insinuating on a public forum that the manual GT3 is not perfection personified will release the full wrath of the Manual GT3 brigade.
You're a brave man indeed...!
PS I just happen to know of a spare place on the FBI's witness protection programme which guarantees full lifetime anonymity..
I am not sure you guys are getting it. I own both a GT3.2 PDK and a GT3T....and they sound very different inside the cabin with PSE on vs off at the same speed. And another GT3T delivered to my dealer sounded the same. Porsche claim there is no difference between a regular GT3 and the GT3T. I say there is. So either both GT3Ts are faulty or there is a difference.
To prove it I will also post videos of my GT3.2 PDK at the same speeds.
OP
Does your car sound like this
Or like this
Or like this
These are all GT3 Ts that sound pretty much the same and all sound good
If your car sound pretty different then take it to the dealer and show them these videos
Or like this
Or like this
[QUOTE=Dalema;14846180]
Interesting- I disconnected the vacuum lines and plugged them so valves are always open. Best Mod
[/QUOTEInteresting- I disconnected the vacuum lines and plugged them so valves are always open. Best Mod
The obvious differences is the air intake scoops and the wing which might make the difference..The only other plausible cause is that Porsche have secretly tuned the PDK and manual GT3s differently for reasons unknown to us punters. It would be interesting to compare the manual winged GT3 to the Touring even just to eliminate the PDK..
OP
Does your car sound like this https://youtu.be/9O7NoFBGYMo
Or like this https://youtu.be/CeCh4XqGBLE
Or like this https://youtu.be/keiO-92keYo
