The "Unofficial" 991.2 GT3 Production Number Stats
#886
so while I agree with you on most points there are a few facts that need to be checked. I agree allocations seem to be done at this point but most all of the allocations for February, March, April builds were handed out in Q4 2018. I can also assure you if your dealer is a top 10 in the US they received a minimum of 20 3RS allocations and over 10 2RS. Regarding .1 3RS PAG always reserved two separate banks of VIN’s for NA. (GS187061-188000 & GS192061-194000) That was never the case with .2 (KS164001-170000).
i haven’t heard many say there will be over 1,700 3RS in the US and after tracking 3RS production since June I’m personally estimating up to 1,775 for N.A. This will break out to roughly 200 for Canada and 1,550 for the USA.
to date there are 1,350 NA GT3RS that have already competed production. Q4 2018 alone they built 750 for N.A.
January they do seem to be a bit slower but will still exceed 100 units and the factory was closed from 12/20/18-1/6/19.
Assuming they continue to build through April/May and average just 100 units per month which is very low output for PAG then we end up with ~1,775 NA 3RS.
I do think we get to the same rough numbers, 15- 1600 USA cars.
Thanks for all the info.
Cheers
#887
I find it interesting that GT3RS vins haven't gone past 165599 in a month or so now. The cars built over that last month or so are all earlier vins; possibly clearing older locked 808 option cars. In the past I've always seen the vins run out well ahead. If they were to stop at 165599 that would be 1536 total cars with around 190 more which have been skipped. It's possible they've added a couple hundred for Feb-Apr?
January production is at around 80 cars with Dec and Nov well into the 200's.
#888
Currently about 250 open vins from 4000 through 5599 but they don’t generally build every single vin and don’t usually go backwards so I’m sure they’ll pick up with 5600+ here shortly.
#890
Is there any way to get this info for 991.1 GT3 production?
#891
2,133 NA 991.1 base GT3 which matches with my numbers as well as Pors9 so I think we can call that one confirmed.
Cams also posted NA 991.1 production (excluding 2012MY 991) but RS and R seem to be quite low compared with Pors9 numbers. Would love to hear from Pors9 regarding this post. Cams 991.2 numbers and my GT numbers match exactly.
#892
I guess because some people see it in non-GT cars that must mean it's needed in a GT car. What about trying to keep the weight of the car down? haha
#894
I'm sure this info is buried in here somewhere, but does anyone know the split on .2 GT3 b/w full leather and the standard interior?
#895
MY - Model - WW - NA
2019 Speedster - 1,948 / 685
2019 GT3RS - 5,000 / 1,775
18/19 GT2RS - 3,900 / 1,375
18/19 GT3 - 9,102 / 3,180
2016 911R - 991 / 323
2016 GT3RS - 4,600 / 1,529
14-16 GT3 - 6,459 / 2,133
991 GT = ~32k WW est. / ~11 NA est
#900
I’m working on an update soon... I ran into a technical issue with how to ascertain the transmission of the car given an inconsistency in how they are represented in the data. More soon.
