Cayman R PSE hack/bypass
Just purchased a 2012 Cayman R.. mint, very low mileage.. very pleased
It are has all the right extras. (well in my non bias opinion) manual, carbon seats ect.
It also has the PSE option.
I have seen that there is a PSE hack where the exhaust valves are completely open all the time..
How much of a difference is it with the bypass, as opposed to "just" pressing the PSE button??
Anybody knows?
Anybody knows?
There is this gizmo: http://www.carnewal.com/products/P57...ust-via-Remote
It's the same as pressing PSE it just allows you to keep it on all the time
This add on box is set up so that you can set the PSE to always be on, I thought that was what you meant. There may be some other sort of hack to do that but I'm unaware of that method. I just use the dash button.
IIRC the valves are normally open until vacuum is placed on them so you can always disconnect the vacuum line leading to the valves so it's always open. You may need to plug the vacuum lines afterward to eliminate vacuum leaks.
I was under the impression that when the disconnection of the vacuum vales was done, the exhaust would become louder either low down or higher up... I guess I was miss informed.. That just leaves me to wonder, who would the the disconnect of the valves?? if all you gain is the very easy push of a button...
after some more digging, found this quote from a guy who has disabled the PSE valves..
Gonna give it a try..
"CaymanSKRD3 years ago
if some asks why would you disconnect it if there is a button too turn it on and off inside the cabin. well there will be still software operating the valve's closing them at certain speeds and rpm too keep it within noise regulations.
so actualy its louder now and in all rpm all the time "
You may be right regarding the valve closing at certain RPM's but without actually disconnecting the valve I can't confirm. I had heard at lower RPM's the valve will close even with PSE turned on but again I can't confirm.
Otherwise you are correct that the only difference is not needing to push the button every time you start the car.
By the way congrats on the new Cayman! I would love to see some pictures of it!
My cars
AUDI R8 V8 rtronic
987 Cayman R
ML 350 AMG
VW VR6 superlegera 8 hrs race car
Previous, to mention a few
Porsche 944, 2xBoxster S 986, 996 C2, Boxster 987 S, 997 S.
Ferrari 458
XKR 2010
BMW M5 E34 , M3 E46
and a whole bunch of other cars....
Basic Sponsor
Congrats on the Cayman R, she is a beauty! Just to confirm, disconnecting the vacuum lines with leave the valves in a default/constant open state. If you are still looking for more sound out of the car (I found the valves open on the PSE to still leave a lot to be desired on my Cayman R), keep the factory PSE and upgrade the headers with either our Race or Sport Headers. The factory headers are the weakest link on the car in regards to performance, and the sound improvement becomes absolutely intoxicating haha.
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Basic Sponsor
Well that is a bummer! However, for your reference Limerock here in the states is limited at 86db. There are several members here on the forum with 987s that run our catless Race Headers, Maxflo Exhaust, and Turn Down Tips and pass the Limerock sound restriction. I think this would be a pretty solid setup for your car considering the circumstances haha
