Boxster S hight speed corner stability issues.
I´ll measure and post here. I ´m thinking seriously to replace also the front tires but when i read that review on EVO (online) long term test (check 3rd paragraph)
http://www.evo.co.uk/carreviews/evol...boxster_s.html
I'm thinking OP tried it on the Autobahn (or the track).
I've never felt stability issues in my 2008 Boxster S at over 100 mph with PSM on - both on the track and highways (latter is definitely NOT recommended unless there's no speed limit ). And I have mismatched tires (rears worn much more and somewhat different wear from side-to-side).
As far as steering feel compared to M3's, could it be the different steering in BMW/M3 vs. Porsche/Boxster S? And do you know if your rear spoiler is deploying as it should? It probably is, but you can double-check by either running it on a dyno or have someone follow you on the highway and go above 75 mph.
I have tracked a variety of cars over the past 30 years, and some did not feel stable to me at high speeds when cornering. The Boxster S certainly does not fit that category. To the contrary the Boxster S is one of the most stable cars that I have driven. Actually the only car that scared the hell out of me was a Corvette Z06 which I drove about 8 years ago. That car had lots of qualities, but handling security was not one of them: one second I'd be in complete control and the next I'd be doing my best to prevent doing a 180.
This is actually a really good suggestion. Unlikely, but still a very good thing to check. One way to see your rear spoiler is, with your top down and over 75 MPH, raise your arm up, and snap a picture/video with your cell phone. Just don't let go!
The spoiler it´s working fine!
Yeah see what the Date codes are on the front tires & how many miles on the car. Also check the tire sidewalls especially close to the wheel for cracks in the rubber from age & sun. It's possible you have the original tires on the front & most tires age harden in 5 years & should be replaced under CPO.
Seems that the guy felt something similar...
Send an email to Pete Stout of Excellence magazine. He'll give you an educated analysis of the Boxster S handling capabilities. He's forgotten more than most sports car magazine writers ever knew about Porsches.
Still plays with cars.
Tire pressures should be around 36 lbs hot. Stock pressures on track will be unstable.
front end can get floaty on mid and rear engine cars. with over 60% of weigh on the rear wheels, it's common.
put a 15lb bag of kitty litter or rice into the front trunk. you'll feel the car is more planted. or better yet, lower that suspension by an inch or so.
I´ll first change the front tires. Tomorrow, i´ll have them fitted ..
