GT3 wheels on Cayman S
8th Gear
Found a nice set of 2002(?) GT3 wheels for sale, and I'm courious if I should pull the trigger.
Front 8J x 18H2-ET50 with 225/40 ZR18s
Rear 11J x 18H2-ET45 with 295/30ZR 18s
One source said they will fit but would need a 5mm spacer on the rear. Somewhat concerned that they might screw up the handleing. Would be used with R compounds for HPDE's.
Anyone ever tried this setup?
The rear is too wide for the car. OEM stagger difference is like 30mm, and the setup you're proposing is 70mm. This setup is fine for a 911 with the motor in the rear, but a mid-engine car would understeer everywhere. 911 and Cayman fitments are not interchangeable.
8th Gear
Thank you for the responce. I was afraid they wouldn't work.
I currently have Carrera Classics:
F 8" x 19" ET57
R 9 1/2" x 19" ET 46
Since I'm still looking for a set of 18" track wheels, would these be the optimum widths & offsets for my 987 without spacers?
F 8 1/2" x 18" ET50
R 10" x 18" ET36
If no, what is recommended?
Are there any OEM Porsche wheels that could be used?
Cost is a concern, as I know Fiske, CCW & others woud make anything I want but I'd rather stay with Porsche wheels.
F 8" x 19" ET57
F 8 1/2" x 18" ET50
R 10" x 18" ET36
8th Gear
Thanks for the reply. Seller had them on a GT2. They look like GT3 wheels, but they might be GT2 wheels. I've moved on to look for wheels that WILL fit, prefering no spacers.
