Having problem with top not closing properly
I have an 05 Boxster and the top does not close properly - the beading on the edge behind the side windows does not go inside the plastic guide on both sides. This was causing a leak on both sides until I figured out that it was not closing properly.
Is there an adjustment to change the position of the top beading? I diod a search but could not find any threads on this issue.
2005 Basalt Black Boxster
2004 Crystal Silver Cayenne S
