Are the new DFI engines bulletproof?
Having had an IMS Failure on my '04 Boxster S in April of this year, I'm wondering if there have been any failures of any kind on the new engines.
I know the new engine does not even have an Intermediate Shaft, so that sounds like it might be a solution to the old problem.
I'm on a 2 year warranty on the new engine and I'm considering a move to a newer car with a DFI engine in the future, at least before the warranty ends.
Engines too new I think to know if they're bullet proof...
BTW, at local Porsche dealer last week and spotted not one but 2 Cayennes in shop each on lift each with engine out. Engine's not torn down though so I think engines were out for some other reason. One Cayenne had its running gear out. I snapped pics of all this.
There has been some talk of the new engine suffering from excessive intake value deposit build up on the intake side of the valve. Since fuel injected in combustion chamber now and not in intake port just ahead of intake valves there is no fuel spray to wash desposits off of valve.
Do not know if this will turn in an Achilles heel of major proportions or just be a problem for a few owners.
Had I not found a Turbo I was seriously thinking of buying a new 2009/2010 Porsche Cayman S with a new DFI engine but not with new PDK but with a 6-speed instead.
You've got some time before you need move to a newer car. Sit back and watch and see what turns up regarding these new engines.
Sincerely,
Macster.
Best Regards,
928 models suffered fron intake port carbon deposits 20 years ago...... At that time the "cure" was to remove the intake manifold and walnut shell blast the ports, clean the injectors and check it ran ok afterwards.
I have seen carbon deposits keeping valves open on one 996 engine this year.
Part of it comes down to slow driving (heavy traffic) stop-start driving (heavy traffic), very short trips and commuting and extended oil changes = engine problems.
Yes. Build up from reverse flow of combustion chamber gases caused...
Hot gases come in contact with relatively cool intake valve and stuff condenses out onto valve.
Also, crankcase fumes pulled out of crankcase and routed to intake to be burned contain still some oil and other stuff which can end up as deposits on valves.
Do not over fill engine with oil. And my advice would be to drain oil more frequently, especially if car not used much. As oil ages build up of water and unburned gas make oil thinner and more likely to foam and aerate. This results in more stuff in crankcase fumes routed to combustion chambers.
Sincerely,
Macster.
