View Poll Results: When changing my oil, should I prefill my oil filter with oil before installation?
It depends on viscosity
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
![](https://rennlist.com/forums/clear.gif)
0
0%
Multiple Choice Poll. Voters: 38. You may not vote on this poll
It seems like a lot of people get tired of talking about oil but not me, I love it. I think it's one of the least understood yet most important keys to reducing engine wear and extending the life of our engines. As Ben Strader, who taught me engine development and tuning at EFI University, always says "application dictates chemistry". And by having your used oil analyzed at labs like SPEEDiagnostix or Blackstone after each change, you can see what oil your engine likes best based on how you use it.
So here's a fun little poll, on a sometimes controversial subject, to get more people thinking about how they care for their engine.
There's a guy on Youtube, he formulated the Driven line of oils, he's done extensive testing. The oil pressure comes up about .02 seconds faster when you prefill the oil filter. IMHO, doesn't matter.
https://www.youtube.com/@themotoroilgeek
Interestingly, when using thinner oils, it absolutely matters. The testing showed that the wear metals increased when not prefilling for a 5W-20, but they did not change for a 20W-50.
This also correlates with why we recommend heavier viscosity oils to be run in these engines, based upon max oil temps. A thicker oil film strength is able to still protect the rod bearings during momentary lapses in oil pressure.
Watch this video for more information or fast forward to 33:00 to see the results.
Flyrod (07-25-2024)
So if it makes a difference on the mid-engine cars where you can actually fill the filter housing because it faces up, why does it not matter on the 992 where you can't because the housing faces down? I guess you could do it on the 992 if you placed the car on a rotisserie and flipped it upside down.
Pre-filling your oil filter when changing the oil is only effective IF your engine is one of those that take oil from the filter then to the high pressure pump then to the engine internals, i.e., filter on the supply side. When I had an air cooled 911, it filtered on the scavenge side. That is, it filtered the oil upon return to the oil tank not to the high pressure pump. Filling that filter beforehand would have no affect on the supply of oil to the engine. I have not confirmed but believe the 9A1 and probably all Porsche flat sixes do this. So there is most likely no need to fill the oil filter since it is not on the supply side. It will be filled when returning oil to the internal sump.
It certainly won't hurt to fill it when installing except that it is easier to make a mess.
Denny Swift (07-22-2024)
On the 987.1’s specifically, the filter is in between the oil pump and the oil cooler. Not filling will cause air to be injected into the system and a brief period of oil starvation to the bearings.
The following 3 users liked this post by SlakkerRacingDev:
If the engine isn't under any load at start up and there is still residual oil in the system, on bearings, etc., does this really matter at all that these components don't get full oil supply for a fraction of a second? Seems like we're making something out of nothing.
The following 3 users liked this post by XuTVJet:
I voted "yes" but realize it is a bit pedantic.... Considering the only time there is ever metal to metal contact is on startup, and that "dry" time is being extended from milliseconds to seconds does not feel good..
But
If it were a concern Porsche would certainly put it in the manual.... if it were a big concern warranty would depend on it...
But
If using a 0w40(which I highly recommend against), and it causes enough wear to show a significant increase in wear metals on a UOA, I would say yes, it absolutely matters. If running a 15w50, probably not as much. But it’s easy to do and since every 987.1S failure we’ve seen in the last 18 mos has been a spun rod bearing, I also consider it worthwhile to try and make people aware of the little things that help prevent the big things.
jscott82 (07-22-2024)
The following 4 users liked this post by Kuro Neko:
If I invest $10 and get a 5% return versus an alternative investment that produces 18%, that’s significant. And it’s also trivial and doesn’t matter.
I would like to see exactly how many oil changes are required with two test groups before one engine fails versus the other. Oil changes only happen every 6-12 months. Are we talking decades here or a century?
I just bought 0w40 rather than 5w40 by mistake. Do I need to cancel the order while I still have time (there are issues with supply so 4-5 wk lead time) or are you specifically saying "highly recommend against" for track use only? There is nothing I've read that says this will be an issue, although I might be missing something!
The oil discussion is about pre filling the filter or not.
