987.1 headliner sag
If you want to replace it with a replacement OEM headliner, the cost of the actual headliner is a little bit north of 2000 USdollars. I replaced it myself (see the article linked below, search on "headliner") but I would imagine an experienced person could do it in 2-3 hours. If you search Rennlist you will find a lot of posts about folks that removed the headliner and glued a replacement fabric to the backing board. I did that to the same car in the article a number of years ago but I wanted to the car to look OEM so I bought the replacement from Porsche for my latest go-around. As to whether the Porsche replacement will fail in the same way, I do not know.
https://newhillgarage.com/2022/09/28...moval-refresh/
For less than $150 in materials, an average DIYer can have the headliner out in less than an hour, the old liner and adhesive removed in 30 minutes, new fabric of their choice applied with fabric spray adhesive, and reinstalled. Lots of people have done this and there are many Youtube videos out there showing the process. OR you can have an interior shop do the work for around $500-800. OR you can spend $2000+ to have Porsche install a OEM panel for you.
Good luck!
