Broken plug update
Old 06-20-2022, 12:44 PM
Gota996
Gota996's Avatar
Default Broken plug update
Gents,
I tried one more time this weekend to get the plug shell out and I succeeded! Used a 12.5MM drill bit, greased and drilled out the major portion of the shell save for the threads. Ran a greased 14Mmx1.25 tapered tap cautiously, about 1/2 turn at a time, removed the tap, cleaned the threads,regreased it, rinse repeat. Took about 45 minutes to run the tap through and it took out the remaining steel threads of the plug. Borscope showed clean threads in the cylinder head and no debris in the cylinder. Swabbed the grease out of the plug hole with lacquer thinner, magnet to pull out any metal parts, nothing stuck to it. I spent about 1/2 hour cleaning out the spark plug hole. Threaded new plug in by hand, then torqued to 22 ft. Lbs. per Porsche spec. Started car, some smoke from the penetrant, no noise, strange sounds. Smoke cleared up, car idled, sounded fine. I was extremely lucky and thankful I had a machinist who helped me along the way with his skill. Putting the covers back on, take the car for a drive first time in over 3 months! Knowing what I know now, this kind of job is best left to the pros. I was stubborn and determined to see it through with the help of friends and my wife’s support. All tole, I spent about $300.00 on drills, tools, and machinist labor. Better than thousands of $$$ to pull the engine and head. But that being said, I would NEVER attempt this repair again. If you intend to change plugs yourself, raise the rear of the car to scoot under it, remove the rear plastic cover and use a 6 inch 3/8” extension to get a straight shot at plug #1&4. Not wonky universals, long extensions blah, blah. Many thanks for your interest and support guys. Have a great summer, I know I will!
The following 16 users liked this post by Gota996:
cavediver32043 (06-22-2022), Charlie C (06-20-2022), emjohn43 (06-20-2022), HETPE3B (06-20-2022), hueyhoolihan (06-20-2022), Mansu944 (06-23-2022), palestar (06-22-2022), plafondles (06-22-2022), RennHarry (06-22-2022), Rocket3004 (06-21-2022), Schwinn (06-21-2022), SFZ GT3 (06-24-2022), The Duke (06-24-2022), TMc993 (06-20-2022), Viper pilot (06-20-2022), ZuffenZeus (06-20-2022) and 11 others liked this post. (Show less...)
Old 06-20-2022, 01:02 PM
Racer Boy
Racer Boy's Avatar
Glad to hear of your success! No go for a drive and enjoy it!
Old 06-20-2022, 01:56 PM
Dave in Chicago
Dave in Chicago's Avatar
Bravo and well done. Best news I've heard today!
Old 06-20-2022, 02:28 PM
jscott82
jscott82's Avatar
Awesome !!! Congrats!
Old 06-20-2022, 06:25 PM
hueyhoolihan
hueyhoolihan's Avatar
i've often wondered if jacking the entire rear-end up and coming at the plugs from underneath would be easier. i'll be trying that next time too.
Old 06-20-2022, 07:26 PM
ZuffenZeus
ZuffenZeus's Avatar
Received 1,712 Likes on 941 Posts
A W E S O M E N E W S!!!!!!!! Congratulations! And, finally some positive news around here for a change!
Please take some pictures, maybe a video celebration?? ha! Love it!
Old 06-20-2022, 08:19 PM
Charlie C
Porsche Nut
Charlie C's Avatar
Excellent news!
Old 06-20-2022, 11:15 PM
ga 951
ga 951's Avatar
SWEET!!!
Now go have some fun with your car after that ordeal!
Old 06-21-2022, 12:22 AM
Kuhl997.2!
Kuhl997.2!'s Avatar
Nothing better than success after perseverance. Thanks for sharing.
Old 06-21-2022, 02:51 AM
qwe
qwe's Avatar
I was pulling for ya, congrats!
Old 06-21-2022, 11:03 AM
mytime1
mytime1's Avatar
Congrats. What a saga. Glad to hear it ended well.
Old 06-21-2022, 03:07 PM
Van Larson
Van Larson's Avatar
Yes, kudos to you. Save your tools/procedural write up summary for a stickie if mods ok.
Old 06-21-2022, 07:27 PM
HETPE3B
HETPE3B's Avatar
I would love to see the tool your fabricator did.
Old 06-21-2022, 07:46 PM
Rocket3004
Rocket3004's Avatar
I was following this thread regularly here and on P9. nice update!!
Awesome! That is some careful operating you did. I think I'd be sweating profusely when using the tap.
So just running the tap through pulled out the shell of the plug? No need for an easy out or anything? Nice.
Old 06-21-2022, 10:22 PM
Richard Toth
Richard Toth's Avatar
I’ll admit this one had me intrigued. It was beginning to feel like episode after episode of Gilligan’s Island. New gadgets and contraptions but rescue still left to the next episode. I was happy when Gilligan, the Skipper and gang we’re finally rescued. I’m happy for you too. Now I need to start watching some reruns.
Chris MI 987 (06-28-2022)
Quick Reply: Broken plug update
