Radio operation without key present?
As far as I have seen, most modern cars will not run the radio without the ignition in ACC mode. These cars are no different. To be clear, on my car (2010 Boxster Base) with an aftermarket radio, just inserting the key turns on the radio. The stock radio may require a rotation of the key, I don't know. In either case, removing the key turns it off, as expected.
I think only older cars had "always on" radios, but to prevent running down the battery, most cars these days will turn it off when the key is removed...
