Door interior switch
Hey Guys,
I'm having an issue with my Cayman where the driver door window doesn't go down when I open the door from the inside. The switch appears to work fine if I press it manually, however the plastic is a bit damaged and the handle doesn't appear to press it properly.
I'm looking for the partnumber of the circled part in the photo. I haven't been able to find it anywhere.
Hey Guys,
Here are some pictures of both parts side by side. The one with the blue plug is the original, only difference between the two (aside from the end of the part number) was the link for the rod to our door handle which was a cable on the Cayenne. The cable end simply slides out and the black plastic Cayman/Boxster part slides on in its place. I highlighted those parts.
I think my door latch mechanism is good since exterior door handle lowers the window fine, interior lights work fine, key fob works as expected. If I use a pen to push the connector rod behind the interior door handle, the window lowers.
I need to replace that connector rod the door latch mechanism attaches too since the part that pokes out of the door is damaged on my car. This is the part I'm looking for. It's circled in red in the first post.
Thanks for the replies!
TMc993 (04-21-2022)
